plisken
save my router backups on a usb stick
Mon May 27, 2019 3:13 pm
Hello, I want to save my router backups on a usb stick instead of files. Can i do that? And if so how should I proceed?
3liswaid
Re: save my router backups on a usb stick
Mon May 27, 2019 4:16 pm
of course you can
it's simple just as you save backup to local storage
you can save on on USB
just connect the USB and format it and you will be able to see it in the files as a new disk
mt99
Mon May 27, 2019 7:11 pm
Assuming you connected the USB, it's formatted, and shows up as disk1 in System -> Disks:
/system backup save name=disk1/yourbackup.backup
plisken
Wed May 29, 2019 6:49 pm
It's working, thanks for yours reply
Greatings
Users browsing this forum: No registered users and 57 guests
