danriis
Simple config but Internet not working.
Wed May 29, 2019 2:01 am
Hi all, I'm replacing a Mikrotik Routerboard 1100AHx4 for a non-profit since they lost the password to the old one. I have general knowledge of networking but not specific to Mikrotik.
Network is just 10.0.0.1/24 so for that I have bridged the router ports and set up DHCP. Port 1 I left with the default Mikrotik IP so it's not in the bridge and neither is the WAN port which is port 13. Problem is no Internet. When I connect the WAN port it becomes 'reachable' according to the router but no Internet. I tried pinging 8.8.8.8 but no go so DHCP doesn't seem to be the issue. Other than that I just have a simple queue with PCQ to share bandwidth. Also using masquerade as I think I'm supposed to when running a private network behind a single public IP. Wondering if my routing table is wrong but I don't know.
Any thoughts would be much appreciated. The config is below:
# may/27/2019 21:56:13 by RouterOS 6.42.7
# software id = CKED-AUWZ
# model = RB1100x4
# serial number = 91D80AE30458
add fast-forward=no name=bridge1
set [ find default-name=ether13 ] name=ether13WAN
add name=dhcp_pool0 ranges=10.0.0.2-10.0.0.245
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
/queue type
set 5 pcq-rate=10M
set 6 pcq-rate=10M
/queue simple
add max-limit=12M/30M name=LimitAll queue=\
    pcq-upload-default/pcq-download-default target=10.0.0.0/24
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=ether7
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=ether9
add bridge=bridge1 interface=ether10
add bridge=bridge1 interface=ether11
add bridge=bridge1 interface=ether12
add address=192.168.88.1/24 comment=defconf interface=ether1 network=\
    192.168.88.0
add address=208.83.199.242 interface=ether13WAN network=208.83.199.252
add address=10.0.0.1/24 interface=bridge1 network=10.0.0.0
add address=10.0.0.0/24 dns-server=10.0.0.1,8.8.8.8 gateway=10.0.0.1
set allow-remote-requests=yes servers=8.8.8.8
add action=drop chain=input comment="DROP SSH from WAN requests" dst-port=22 \
    in-interface=ether13WAN protocol=tcp
add action=drop chain=input comment="DROP webconfig from WAN requests" \
    dst-port=8081 in-interface=ether13WAN protocol=tcp
add action=drop chain=input comment="DROP Winbox from WAN requests" dst-port=\
    8291 in-interface=ether13WAN protocol=tcp
add distance=1 gateway=208.83.199.241
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=0.0.0.0/0 port=8081
set ssh address=10.0.0.0/24
set api disabled=yes
set winbox address=0.0.0.0/0
set api-ssl disabled=yes
/system clock
set time-zone-name=US/Pacific
/system identity
set name=MikroTikLV
/system routerboard settings
set silent-boot=no
/tool graphing interface
add
karlisi
Re: Simple config but Internet not working.
Wed May 29, 2019 9:46 am
Try this
add action=masquerade chain=srcnat out-interface=ether13WAN
Not related to connection problems, but You have very insecure firewall rules. In input chain You should block everything, allowing only needed inputs. Also, forward chain is empty.
Karlis
Users browsing this forum: No registered users and 54 guests
