SpongeB0B
Enable NTP Client
Wed May 29, 2019 10:39 am
HI everyone,
I just bought a Hex (RB750Gr3) I would like to get the time for this device trough NTP.
I see SNTP but no NTP, I dig inside the online manual but couldn't ound how to enable/install a NTP client..
Thanks B0B
Device: Hex: RB750Gr3
normis
Re: Enable NTP Client
Wed May 29, 2019 10:52 am
SNTP is the same, you need that one
NTP package has also server, if you don't need it, use SNTP, it's more functional
SpongeB0B
Wed May 29, 2019 11:02 am
Thank you @normis
Yes I just need FTP client functionality. Let say I would like to use this server NTP.example.com
So I can let the first Primary NTP server as 0.0.0.0 ?
karlisi
Re: Enable NTP Client  [SOLVED]
Wed May 29, 2019 4:23 pm
Yes
Karlis
krafg
Thu May 30, 2019 7:04 am
I usually use how first the official NTP server of my country and then time.windows.com
Regards.
Users browsing this forum: No registered users and 75 guests
