nksandor
/ip cloud [ddns], VPN and Winbox access
Fri Jun 07, 2019 6:45 pm
Best Greetings for All of You!
I have some problems with the setup of my device, wich is an RB750G, firmware 6.44.3;
- ether1 (WAN1) ADSL modem PPPoE with fix IP from the ISProvider;
- - bridge1: ether2, ether3 (without pool addresses, all client has fix ip);
- ether4 (WAN2) DHCP client, address from an optical modem/router (IP from router DHCP, 192.168.0.135);
- - bridge2: ether5 (pool 10.127.1.0/24);
  • One
I would like to know the external IP on the optical connection. It is OK with the linux "curl" command from a PC on the bridge2, but maybe there is another way too with RouterOS. (fetch command?, but how to redirect to ether4 from ether1)
On the ether1 the "/ip cloud" works, but it's information is irrelevant. (fix ip)
  • Two
I have build the OpenVPN and L2TP/IPSec servers with different pools (10.8.3.1 on OpenVPN, and 10.8.4.1 on the other VPN). The connection works good on both VPN's, on the same time too, but I dont see the bridge2 pool's clients. The clients on the bridge1 are all visible. (ssh, MS rdp, http, https ...)
  • Three
If I know the external address on the optical modem/router, the access - such WinBOX, or the VPN access - from the ether4/internet does not working. Filter rules (8291, 1194, 500, 1701, 4500) are OK. I think. On the bridge2's loop there is a Net DVR, and the access to this device is fine on the adjusted port (port forwarded).
Users browsing this forum: No registered users and 81 guests
