Dear Mikrotik,
We have a new wAP LTE kit. https://mikrotik.com/product/wap_lte_kit
As stated there "The wAP LTE also has one 10/100 Ethernet LAN port for your wired devices." .. so far so good.
After setting up the sim card, there is internet on the wireless network the device provides, but not on the wired Ethernet LAN port.
Is this on purpose, if yes, why?
I would assume, connecting to the internet with LTE as WAN, and both wireless and ethernet as LAN would work out of the box.
- The WLAN and the LAN devices are on the same network and can communicate with each other, and with the router.
- I can ping a public ip, 8.8.8.8 on a wireless connected device, but not on a device connected on the wire.
Is this a bug in the initial configuration?
If yes, when would be a fix released? What needs to be set so it works as expected?
If no, could there be a Quick Set preset for this simple scenario - as advertised on the product page?
Please advise as soon as possible, I need to get this configuration done ASAP. I have a deadline, and must provide internet on a wire.
Thank you.
