So in the picture you may see the structure of the network. Any advice is appreciated . What would be the best way to set up DHCP so that VLAN devices are getting IP if one of the L3 devices is down, at the moment i see only one option to supernet IP and divide in to half and create two DHCP's with the same subnet mask and with different gateways. But I dont like that splitting as I will have to much of play with statically assigning IP's those i don't want to be changed.
Is where any other better way to achieve this.
Thanks in advance.
