YazzY
Bridge problems.
Fri May 28, 2004 5:26 pm
Hi.
I have encountered a strange thing.
I've set up eth1 and wlan1 in bridge, eth1 had an IP , say 192.168.1.10
Then I added IP to the bridge interface, 192.168.1.2
I could ping both just fine from my backbone gateway 192.168.1.1 and all the other RouterOS boxes.
But when I removed the IP of the eth1 interface , the box got unreachable.
Why did that happen? Shouldn't i still be able to ping the IP of the bridge ?
dwright
Fri May 28, 2004 9:57 pm
Hey Yazzy,
Try to put a switch or hub in between the two and see if you can pass traffic. I had the same problem with a router board bridge eth and wireless and was connected to another Mikrotik router which acted as our gateway. Couldn't explain it either.
Dan
dwright
Fri May 28, 2004 10:16 pm
Also make sure that you are bridging ip and arp and that you added your interfaces to the bridge.
YazzY
No love
Sat May 29, 2004 12:31 am
It's kinda impossible.
The AP is connected to another AP which is connected to a switch.
The gateway box is also connected to the same switch.
I've flushed my arp table on the gateway and I am bridging both the IP and ARP.
Thanks gods for the arp-telnet which made it possible to login to the box anyway.
I managed to remove all the IPs on all the ifaces, remove all the routes and then add new IP and route.
It worked with IP given to the bridge only.
There is some strange behaviour anyway, adding default route on the bridged iface without removing IP of the bridge first does not work. The route gets assigned to an unknown interface then...
rz8168
Sun Jun 06, 2004 1:01 am
did you add static route to bridge?
Users browsing this forum: achenor, sindy and 67 guests
