MUM Europe 2020
Datanav
Keyword search term filtering
Mon Jul 15, 2019 8:53 pm
Folks,
Can the routerOS currently do the above? I.e. If i have blocked the keyword "porn", anyone who uses the any search engine, the RouterOs will perform "man in the middle" operations and block the search.
Regards,
DataNav
sindy
Re: Keyword search term filtering
Tue Jul 16, 2019 11:00 am
Not on https or other encrypted connections, as RouterOS doesn't do the actual MITM in the security-related meaning of the term; to some extent, with a high probability of false positives, you can do that on plaintext protocols like http using /ip firewall layer7-protocol.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Jotne
Tue Jul 16, 2019 11:25 am
You can not do that with Mikrotik router since HTTPS packet are encrypted.
But with a corporate network that controlling the PC, you can use products like Forcepoint (https://www.forcepoint.com/)
When you do surfing it will replace the HTTPS certificates and Forcepont will surf on behalf of the clients.
Our company do use system like this so my search at work are restricted.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Users browsing this forum: aboiles, arnoldmikro, Bing [Bot], MSN [Bot] and 89 guests
