onlineuser
socks proxy with remote dns
Wed Jul 17, 2019 10:16 pm
is it possible to use the socks proxy server on a mikrotik router with remote dns?
I tried to set up but it was not possible that the router opened an outgoing connection to the target server.
Sob
Re: socks proxy with remote dns
Wed Jul 17, 2019 11:46 pm
The answer is no. SOCKS server in RouterOS is terribly outdated, it supports only SOCKS4, i.e. no hostnames, only numeric IP addresses.
Excessive quoting is useless and annoying. If you use it, please consider if you could do without it.
onlineuser
Tue Feb 11, 2020 9:45 pm
Thanks.
It would be nice if ROS would get any "real" SOCKS proxy implementation (srelay would be a open source socks proxy).
Sob
Wed Feb 12, 2020 12:39 am
Somewhat unexpectedly, things changed for the better since last time. RouterOS 6.47 (currently in beta) has SOCKS5, and not just the simplest CONNECT command for outgoing connections. It also handles incoming connections with BIND command (I'm not sure if correctly, it doesn't seem to return bind address), and even UDP association may be there (it responds with success code when requested, but I don't think I have anything to test it properly).
onlineuser
Thu Feb 13, 2020 12:37 pm
It's sad.
On OpenWrt based devices it's no problem to compile any package you need.
Mikrotik should begin to integrate some additional packages which the community want to use.
They offer some packages like ntpd, hotspot, ups, advanced-tool and etc. but I miss socks proxy (srelay) or an authoritatived dns server (maradns or powerdns). All of this helpful tools are lightweight and could be used on non-busy Mikrotik routers.
Sob
Thu Feb 13, 2020 2:03 pm
Why sad? There's now SOCKS5 server and it works. You wanted remote DNS, which I assume means client giving hostnames to server (instead of locally resolved IP addresses) and server resolving them, and it's there.
skylark
Thu Feb 13, 2020 3:35 pm
We are working on SOCK5 improvements, please be patient. :)
onlineuser
Thu Feb 13, 2020 4:49 pm
Sorry, I read it inaccurately.
Good news. :-)
onlineuser
Sun Oct 11, 2020 10:55 am
Are there any news about the new feature?
onlineuser
Wed Feb 17, 2021 4:25 pm
Any news about this feature?
Users browsing this forum: Bing [Bot], clan, mciupak, nagylzs, tdw, wpeople and 167 guests
