Pericles
Link Failover
Fri Jul 19, 2019 4:30 pm
I am trying to co-configure link failover between the wan ports of rb2011 version 6.40.3. I have 2 ip 41.221.xxx.xxx/30 GW 41.221.xxx.xxx and the second is 41.221.205.121/30 and GW 41.xxx.xxx.xxx. when I physically disconnect one of the interfaces I lose the connection and the second link does not stay up
sebastia
Re: Link Failover
Fri Jul 19, 2019 4:56 pm
Hey
Note: don't post your public ip's in clear, at least some masking is advised.
The behaviour you describe is unexpected: one link should not impact the other. But to have better view...
Please post your config: "/export hide-sensitive" (mask consistently your public ip's)
Pericles
Re: Link Failover
Fri Jul 19, 2019 6:59 pm
Hi, thanks for the tip
my configuration
Doc1.docx
sebastia
Re: Link Failover
Sat Jul 20, 2019 1:20 am
Try posting the config between [ code ] [/ code ] tags. (without spaces between [])
I tend to not open an unknown docx document from net...
Pericles
router hang up whnen i try to access ip firewall
Tue Sep 17, 2019 3:00 pm
why whenever I try to access Mikrotik router in winbox through Mac hangs up whenever I try to access IP Firewall.
Users browsing this forum: anav, Baidu [Spider], jugene, kai and 71 guests
