rd228
RB2011UiAS-RM - High CPU on Download
Fri Jul 19, 2019 5:06 pm
Hi all,
Looking for some help here as im now stuck after trying a few suggestions on the forums.
I am using a RB2011UiAS-RM with BT Fibre to the premises broadband. I have just upgraded from 50 down 10 up to 150 down 30 up.
My upload speeds are reaching 30mbps fine. My downloads however are fluctuating between 80/90mbps and wont go much higher. Looking at my CPU during the download when running a speed test its running at a constant 99/100%. I'm guessing this is going to be the restriction on why it wont go above 90 for a download?
Anything I can try to resolve this problem? Can post my config if required.
Ross
sebastia
Re: RB2011UiAS-RM - High CPU on Download
Fri Jul 19, 2019 5:27 pm
Hi
Do you have the latest version of ROS? If not upgrade.
Do you have any special configuration? I would suggest to perform a factory reset to default config for homeAP. This config can do 800+ out of the box.
freemannnn
Long time Member
Long time Member
Fri Jul 19, 2019 5:53 pm
Turn on fasttrack rule in ip firewall filter
Steveocee
Fri Jul 19, 2019 6:00 pm
Hate to be the one to ask.
Your WAN port is in 1-5 not 6-10? Only 1-5 are Gigabit.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
rd228
Fri Jul 19, 2019 8:38 pm
To answer all of your questions -
I havent got fast track enabled. I think I decided a while ago not to turn it on as it stops some other things working in the router when its enabled that I currently used at the time.
I am on the latest version, and my WAN port is in port 1 which is connected to a PPPoE interface in the router.
rd228
Fri Jul 19, 2019 9:06 pm
I also know its not my firewall rules as I have disabled them all and tried another speed test.
sebastia
Sat Jul 20, 2019 1:14 am
2011 is not that powerful (cpu-wise), but it shouldn't be as bad
See https://www.youtube.com/watch?v=BMNoRJ4Wy3E
There were some topic regarding 2011 throughput, have a look.
Also not that FastTrack can be enabled selectively, it's not all-or-nothing switch.
Finally, if you need more input, post your config + network topology.
Users browsing this forum: No registered users and 89 guests
