robintk
digital-signature with ipsec EAP -identity not found for server:MYSN.sn.mynetname.net peer: ADDR4: 10.223.14.39
Tue Jul 23, 2019 11:23 am
MobilePhone:APPLE X Version 12.2
RouterBoard:951-2n Fireware:6.45.2 routeos-mipsbe:6.45.2(all packages)
CA(pem) and client Certificate(p12) has been installed in my phone and verified.
The log show identity can't find ip "10.223.14.39" but I ever config IP on my server and client like 10.223.14.39,it realiy strange.(I left the LOCAL ID blank for ikev2 config in my phone)
If I config Local ID in the phone same as common name of certificate like apple01 , the error will change to " identity not found for server:MYSN.sn.mynetname.net peer:FQDN:apple01"
I need you help,thanks a lot in advance.@sindy
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: ff
Jul/23/2019 15:59:36 ipsec 2222: payload seen: ID_I (12 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: NOTIFY (8 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: ID_R (37 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: CONFIG (40 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: SA (200 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: TS_I (64 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: TS_R (64 bytes)
Jul/23/2019 15:59:36 ipsec 2222: processing payloads: NOTIFY
Jul/23/2019 15:59:36 ipsec 2222:   notify: INITIAL_CONTACT
Jul/23/2019 15:59:36 ipsec 2222:   notify: MOBIKE_SUPPORTED
Jul/23/2019 15:59:36 ipsec 2222:   notify: ESP_TFC_PADDING_NOT_SUPPORTED
Jul/23/2019 15:59:36 ipsec 2222:   notify: NON_FIRST_FRAGMENTS_ALSO
Jul/23/2019 15:59:36 ipsec 2222: ike auth: respond
Jul/23/2019 15:59:36 ipsec 2222: processing payload: ID_I
Jul/23/2019 15:59:36 ipsec 2222: ID_I (ADDR4): 10.223.14.39
Jul/23/2019 15:59:36 ipsec 2222: processing payload: ID_R
Jul/23/2019 15:59:36 ipsec 2222: ID_R (FQDN): MYSN.sn.mynetname.net
Jul/23/2019 15:59:36 ipsec 2222: processing payload: AUTH (not found)
Jul/23/2019 15:59:36 ipsec 2222: requested server id: MYSN.sn.mynetname.net
Jul/23/2019 15:59:36 ipsec,error 2222: [b][color=#FF0000]identity not found for server:MYSN.sn.mynetname.net peer: ADDR4: 10.223.14.39[/color][/b]
Jul/23/2019 15:59:36 ipsec 2222: reply notify: AUTHENTICATION_FAILED
Jul/23/2019 15:59:36 ipsec 2222: adding notify: AUTHENTICATION_FAILED
Jul/23/2019 15:59:36 ipsec,debug 2222: => (size 0x8)
Jul/23/2019 15:59:36 ipsec,debug 2222: 00000008 00000018
Jul/23/2019 15:59:36 ipsec 2222: <- ike2 reply, exchange: AUTH:1 122.96.40.70[58612]
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: => outgoing plain packet (size 0x24)
config:
add common-name=ca name=CA  days-valid=365
sign CA ca-crl-host=40d202c59f3b.sn.mynetname.net
add common-name=MYSN.sn.mynetname.net subject-alt-name=DNS:MYSN.sn.mynetname.net key-usage=tls-server name=server01
sign server01 ca=CA
add common-name=apple01  key-usage=tls-client name=apple01
sign apple01 ca=CA
 /ip ipsec profile
add name=apple01
/ip ipsec proposa
add name=apple01 pfs-group=none
add name=apple01 ranges=192.168.100.20-192.168.100.254
/ip ipsec mode-config
add address-pool=apple01 name apple01 system-dns=yes address-prefix-length=32
/ip ipsec policy group
add name=apple01
/ip ipsec policy
 add dst-address=192.168.200.0/24 group=apple01 proposal=apple01 src-address=0.0.0.0/0 template=yes
 /ip ipsec peer
add exchange-mode=ike2  name=apple01 passive=yes profile=apple01  send-initial-contact=no
 /ip ipsec identity
add auth-method=digital-signature  certificate=server01  generate-policy=port-strict  match-by=certificate  mode-config=apple01 peer=apple01 policy-template-group=apple01 remote-certificate=apple01
ERROE LOG:
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: 4a68b938 e32711bf d3e8e03c 6bcc9d71 29202320 00000001 00000024 00000008
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: 00000018
Jul/23/2019 15:54:04 ipsec 2222: adding payload: ENC
Jul/23/2019 15:54:04 ipsec,debug 2222: => (size 0xc0)
Jul/23/2019 15:54:04 ipsec,debug 2222: 290000c0 4b4d13be f97d8eaa 92edd3aa 66434689 6629e69c 252f5cc4 30972fa8
Jul/23/2019 15:54:04 ipsec,debug 2222: 987509d6 b676f7ba 7c52f7d7 8390f0eb ced89c57 2256973f d4fb494e bc82b3fd
Jul/23/2019 15:54:04 ipsec,debug 2222: 141f87f3 48597d62 005ab1b6 2ba45805 92510495 00ad5c0c a8366813 2b2764c6
Jul/23/2019 15:54:04 ipsec,debug 2222: 4e547c76 8ffa5d1a 3701c6b4 ba8a1f62 4c12973d 1ec2622e de0d8927 d023ab8f
Jul/23/2019 15:54:04 ipsec,debug 2222: 4939c563 708e866f 56cdd5f0 839e4c44 d65760f7 0080921b 2d8c30a7 f4148cea
Jul/23/2019 15:54:04 ipsec,debug 2222: 4420a51b 3d5be117 8e270f5d b07f571f 4bf5ef58 00000000 00000000 00000000
Jul/23/2019 15:54:04 ipsec,debug 2222: ===== sending 220 bytes from 122.96.77.59[4500] to 122.96.40.70[58605]
Jul/23/2019 15:54:04 ipsec,debug 2222: 1 times of 224 bytes message will be sent to 122.96.40.70[58605]
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: 4a68b938 e32711bf d3e8e03c 6bcc9d71 2e202320 00000001 000000dc 290000c0
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: 4b4d13be f97d8eaa 92edd3aa 66434689 6629e69c 252f5cc4 30972fa8 987509d6
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: b676f7ba 7c52f7d7 8390f0eb ced89c57 2256973f d4fb494e bc82b3fd 141f87f3
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: 48597d62 005ab1b6 2ba45805 92510495 00ad5c0c a8366813 2b2764c6 4e547c76
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: 8ffa5d1a 3701c6b4 ba8a1f62 4c12973d 1ec2622e de0d8927 d023ab8f 4939c563
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: 708e866f 56cdd5f0 839e4c44 d65760f7 0080921b 2d8c30a7 f4148cea 4420a51b
Jul/23/2019 15:54:04 ipsec,debug,packet 2222: 3d5be117 8e270f5d b07f571f 4bf5ef58 a646f96f b17af1a7 dff6309f
Jul/23/2019 15:54:04 ipsec,info 2222: killing ike2 SA: 122.96.77.59[4500]-122.96.40.70[58605] spi:d3e8e03c6bcc9d71:4a68b938e32711bf
Jul/23/2019 15:54:04 ipsec 2222: KA remove: 122.96.77.59[4500]->122.96.40.70[58605]
Jul/23/2019 15:54:04 ipsec,debug 2222: KA tree dump: 122.96.77.59[4500]->122.96.40.70[58605] (in_use=1)
Jul/23/2019 15:54:04 ipsec,debug 2222: KA removing this one...
Jul/23/2019 15:54:08 ipsec,debug 2222: 0.0.0.0[500] used as isakmp port (fd=26)
Jul/23/2019 15:54:08 ipsec,debug 2222: 0.0.0.0[4500] used as isakmp port with NAT-T (fd=28)
Jul/23/2019 15:54:11 ipsec,debug 2222: failed to bind to ::[500] Bad file descriptor
Jul/23/2019 15:54:13 ipsec,debug 2222: 0.0.0.0[500] used as isakmp port (fd=26)
Jul/23/2019 15:54:13 ipsec,debug 2222: 0.0.0.0[4500] used as isakmp port with NAT-T (fd=28)
Jul/23/2019 15:54:16 ipsec,debug 2222: failed to bind to ::[500] Bad file descriptor
Jul/23/2019 15:54:17 ipsec,debug 2222: ===== received 604 bytes from 122.96.40.70[14967] to 122.96.77.59[500]
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 65c3d6b0 5a805900 00000000 00000000 21202208 00000000 0000025c 220000dc
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 0200002c 01010004 0300000c 0100000c 800e0100 03000008 02000005 03000008
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 0300000c 00000008 0400000e 0200002c 02010004 0300000c 0100000c 800e0100
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 03000008 02000005 03000008 0300000c 00000008 04000013 0200002c 03010004
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 0300000c 0100000c 800e0100 03000008 02000005 03000008 0300000c 00000008
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 04000005 0200002c 04010004 0300000c 0100000c 800e0080 03000008 02000002
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 03000008 03000002 00000008 04000002 00000028 05010004 03000008 01000003
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 03000008 02000002 03000008 03000002 00000008 04000002 28000108 000e0000
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: d2ff0d15 d00aea5d e6abdc3a 5e824504 40bc5b4d b957a729 22b84683 893b3d5f
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 1d044e17 b8b39658 052e2f40 57508cfd c8aec0e0 a56cf0df 6433864a 70b3477a
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 66744861 d7dd6962 88f9d98f afdeb978 5c028af0 a3223921 56c7dbd1 5a06caba
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 686dde5d 6f607afc ca08a821 e21e0315 5bc3a5da e9442f0c 9b605680 2930e9ef
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 7c5dc8aa d58f040c f244f0c5 21cc5e85 384cb933 2ecaa31f c833ef3e 4328c8da
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 8dc8e73f 83639e77 0a457609 f96b2499 a60d541c 4335459f f7d8c67c b5454a39
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: b37f50c1 55dd15d9 0ecccec5 a8d9181d 38b44aae 2ff7c73b a5e7d915 759bcb41
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 7a300a5f 7175defe 23f777ae 0f8eb6ac 63282e3d 6451e00a 5ddad849 836b37ec
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 29000014 f4098429 bc4e94b8 f5698e98 17583476 29000008 00004016 2900001c
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 00004004 b388b7ec 2670f79c d7d2e792 16ffc745 940a6c49 2900001c 00004005
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 6481cc70 c49f1718 b7b8d390 2dbb7658 e7988c04 00000008 0000402e
Jul/23/2019 15:54:17 ipsec 2222: -> ike2 request, exchange: SA_INIT:0 122.96.40.70[14967]
Jul/23/2019 15:54:17 ipsec 2222: ike2 respond
Jul/23/2019 15:54:17 ipsec 2222: payload seen: SA (220 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: KE (264 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: NONCE (20 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: NOTIFY (8 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: NOTIFY (28 bytes)
Jul/23/2019 15:54:17 ipsec 2222: processing payload: NONCE
Jul/23/2019 15:54:17 ipsec 2222: processing payload: SA
Jul/23/2019 15:54:17 ipsec 2222: IKE Protocol: IKE
Jul/23/2019 15:54:17 ipsec 2222: proposal #1
Jul/23/2019 15:54:17 ipsec 2222: enc: aes256-cbc
Jul/23/2019 15:54:17 ipsec 2222: prf: hmac-sha256
Jul/23/2019 15:54:17 ipsec 2222: auth: sha256
Jul/23/2019 15:54:17 ipsec 2222: dh: modp2048
Jul/23/2019 15:54:17 ipsec 2222: proposal #2
Jul/23/2019 15:54:17 ipsec 2222: dh: ecp256
Jul/23/2019 15:54:17 ipsec 2222: proposal #3
Jul/23/2019 15:54:17 ipsec 2222: dh: modp1536
Jul/23/2019 15:54:17 ipsec 2222: proposal #4
Jul/23/2019 15:54:17 ipsec 2222: enc: aes128-cbc
Jul/23/2019 15:54:17 ipsec 2222: prf: hmac-sha1
Jul/23/2019 15:54:17 ipsec 2222: auth: sha1
Jul/23/2019 15:54:17 ipsec 2222: dh: modp1024
Jul/23/2019 15:54:17 ipsec 2222: proposal #5
Jul/23/2019 15:54:17 ipsec 2222: enc: 3des-cbc
Jul/23/2019 15:54:17 ipsec 2222: matched proposal:
Jul/23/2019 15:54:17 ipsec 2222: processing payload: KE
Jul/23/2019 15:54:17 ipsec 2222: DH group number mismatch: 2 != 14
Jul/23/2019 15:54:17 ipsec 2222: adding notify: INVALID_KE_PAYLOAD
Jul/23/2019 15:54:17 ipsec,debug 2222: => (size 0xa)
Jul/23/2019 15:54:17 ipsec,debug 2222: 0000000a 00000011 0002
Jul/23/2019 15:54:17 ipsec,debug 2222: ===== sending 38 bytes from 122.96.77.59[500] to 122.96.40.70[14967]
Jul/23/2019 15:54:17 ipsec,debug 2222: 1 times of 38 bytes message will be sent to 122.96.40.70[14967]
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 65c3d6b0 5a805900 00000000 00000000 29202220 00000000 00000026 0000000a
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 00000011 0002
Jul/23/2019 15:54:17 ipsec,debug 2222: ===== received 476 bytes from 122.96.40.70[14967] to 122.96.77.59[500]
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 65c3d6b0 5a805900 00000000 00000000 21202208 00000000 000001dc 220000dc
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 03000008 02000002 03000008 03000002 00000008 04000002 28000088 00020000
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 75359332 afd0073d 2ca6ca0f c8241e7f a71c08f8 046554ee 88306304 c86a7d95
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: c4502b21 98d969a9 829c1162 6e469d58 cbe7ed7d 315ec9b5 126675ed 33f2ab84
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 8dbe489c 35014abc f03470a9 0c16b6bf 93da2c35 575a2137 5e292082 a22c874b
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 9535e069 432010b1 1c614c93 47a361b4 57592203 c358e4b7 13688d3a 60642045
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 29000014 ca3706fd a581e88e 826db2b9 94b572c5 29000008 00004016 2900001c
Jul/23/2019 15:54:17 ipsec 2222: payload seen: KE (136 bytes)
Jul/23/2019 15:54:17 ipsec,debug 2222: => shared secret (size 0x80)
Jul/23/2019 15:54:17 ipsec,debug 2222: 7b9cc143 b24968ae b7a5ac50 4b5baabf b66caf77 fa3dbc34 19b82e51 2cfe0458
Jul/23/2019 15:54:17 ipsec,debug 2222: 02056319 062e60a9 b888dab0 5e704ef5 d2f6d477 78d1ba8a 51041d3e 1378a7c7
Jul/23/2019 15:54:17 ipsec,debug 2222: 479ab036 72abe27c b56e54c2 05bc52c6 abecab03 29ee4f3f 8f17b5ed dd36ec5f
Jul/23/2019 15:54:17 ipsec,debug 2222: e6dcc451 2576f9f2 1058702d 1b6bf754 ebea7b2c 6eb45aa7 1b178914 052d91d6
Jul/23/2019 15:54:17 ipsec 2222: adding payload: SA
Jul/23/2019 15:54:17 ipsec,debug 2222: => (size 0x30)
Jul/23/2019 15:54:17 ipsec,debug 2222: 00000030 0000002c 01010004 0300000c 0100000c 800e0080 03000008 02000002
Jul/23/2019 15:54:17 ipsec,debug 2222: 03000008 03000002 00000008 04000002
Jul/23/2019 15:54:17 ipsec 2222: adding payload: KE
Jul/23/2019 15:54:17 ipsec,debug 2222: => (size 0x88)
Jul/23/2019 15:54:17 ipsec,debug 2222: 00000088 00020000 fcdd45fa d3eca650 51dbef1d f6876e64 6bb8e074 54309a4d
Jul/23/2019 15:54:17 ipsec,debug 2222: d6ef2e49 65068572 96fabb21 00d2f5b9 0a391f81 e21fbe2b 7ab11d4d 41f429ee
Jul/23/2019 15:54:17 ipsec,debug 2222: 50d6578d 345689ed 2425e211 8a5a23cd b909e100 b79f7802 eb6a7b3c 6e32fc1b
Jul/23/2019 15:54:17 ipsec,debug 2222: f14ad1f7 e7c3c5aa 741d8bf7 21cd9593 e5ca130f 4e48d79f 5c329f9f da41ab45
Jul/23/2019 15:54:17 ipsec,debug 2222: b37e6089 7d3ffd52
Jul/23/2019 15:54:17 ipsec 2222: adding payload: NONCE
Jul/23/2019 15:54:17 ipsec,debug 2222: => (size 0x1c)
Jul/23/2019 15:54:17 ipsec,debug 2222: 0000001c 10f74930 020b18e8 6c4f9b7f 0b8556ab 19da39fe cc100ff5
Jul/23/2019 15:54:17 ipsec 2222: adding notify: NAT_DETECTION_SOURCE_IP
Jul/23/2019 15:54:17 ipsec,debug 2222: 0000001c 00004004 dc63a333 97dd6ef1 a815d775 e2e162fb f1c232bd
Jul/23/2019 15:54:17 ipsec 2222: adding notify: NAT_DETECTION_DESTINATION_IP
Jul/23/2019 15:54:17 ipsec,debug 2222: 0000001c 00004005 910ff14e 83dba035 55d2caf2 0c0475db e8e31d21
Jul/23/2019 15:54:17 ipsec 2222: adding payload: CERTREQ
Jul/23/2019 15:54:17 ipsec,debug 2222: => (size 0x5)
Jul/23/2019 15:54:17 ipsec,debug 2222: 00000005 04
Jul/23/2019 15:54:17 ipsec 2222: <- ike2 reply, exchange: SA_INIT:0 122.96.40.70[14967]
Jul/23/2019 15:54:17 ipsec,debug 2222: ===== sending 301 bytes from 122.96.77.59[500] to 122.96.40.70[14967]
Jul/23/2019 15:54:17 ipsec,debug 2222: 1 times of 301 bytes message will be sent to 122.96.40.70[14967]
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 65c3d6b0 5a805900 24ec6cab 97a8445c 21202220 00000000 0000012d 22000030
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 0000002c 01010004 0300000c 0100000c 800e0080 03000008 02000002 03000008
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 03000002 00000008 04000002 28000088 00020000 fcdd45fa d3eca650 51dbef1d
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: f6876e64 6bb8e074 54309a4d d6ef2e49 65068572 96fabb21 00d2f5b9 0a391f81
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: e21fbe2b 7ab11d4d 41f429ee 50d6578d 345689ed 2425e211 8a5a23cd b909e100
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: b79f7802 eb6a7b3c 6e32fc1b f14ad1f7 e7c3c5aa 741d8bf7 21cd9593 e5ca130f
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 4e48d79f 5c329f9f da41ab45 b37e6089 7d3ffd52 2900001c 10f74930 020b18e8
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 6c4f9b7f 0b8556ab 19da39fe cc100ff5 2900001c 00004004 dc63a333 97dd6ef1
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: a815d775 e2e162fb f1c232bd 2600001c 00004005 910ff14e 83dba035 55d2caf2
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 0c0475db e8e31d21 00000005 04
Jul/23/2019 15:54:17 ipsec,debug 2222: => skeyseed (size 0x14)
Jul/23/2019 15:54:17 ipsec,debug 2222: 968d7f60 62617730 8aeadb26 83a6b650 76cbcab5
Jul/23/2019 15:54:17 ipsec,debug 2222: => keymat (size 0x14)
Jul/23/2019 15:54:17 ipsec,debug 2222: 46d3399d e96f3fe0 088a624c e9e052f6 ec141aae
Jul/23/2019 15:54:17 ipsec,debug 2222: => SK_ai (size 0x14)
Jul/23/2019 15:54:17 ipsec,debug 2222: 79283c3f 38c51804 424ac9cf bd8919ae e3caa9b1
Jul/23/2019 15:54:17 ipsec,debug 2222: => SK_ar (size 0x14)
Jul/23/2019 15:54:17 ipsec,debug 2222: 4918a641 a5734cc9 63dd7649 27df7844 93204f8f
Jul/23/2019 15:54:17 ipsec,debug 2222: => SK_ei (size 0x10)
Jul/23/2019 15:54:17 ipsec,debug 2222: 85545962 2fc60875 21d68c0c 403f34e3
Jul/23/2019 15:54:17 ipsec,debug 2222: => SK_er (size 0x10)
Jul/23/2019 15:54:17 ipsec,debug 2222: 3c047b95 76d2d5ab 5201f4d7 6bf910c0
Jul/23/2019 15:54:17 ipsec,debug 2222: => SK_pi (size 0x14)
Jul/23/2019 15:54:17 ipsec,debug 2222: d0298ffa 0bd2cc87 4a9318aa 61312193 525e8b79
Jul/23/2019 15:54:17 ipsec,debug 2222: => SK_pr (size 0x14)
Jul/23/2019 15:54:17 ipsec,debug 2222: 130e8a5d b35b254f 00416bf6 a5eb4d90 39b3034b
Jul/23/2019 15:54:17 ipsec,info 2222: new ike2 SA (R): 122.96.77.59[500]-122.96.40.70[14967] spi:24ec6cab97a8445c:65c3d6b05a805900
Jul/23/2019 15:54:17 ipsec 2222: processing payloads: VID (none found)
Jul/23/2019 15:54:17 ipsec 2222: processing payloads: NOTIFY
Jul/23/2019 15:54:17 ipsec 2222: notify: REDIRECT_SUPPORTED
Jul/23/2019 15:54:17 ipsec 2222: notify: NAT_DETECTION_SOURCE_IP
Jul/23/2019 15:54:17 ipsec 2222: notify: NAT_DETECTION_DESTINATION_IP
Jul/23/2019 15:54:17 ipsec 2222: notify: IKEV2_FRAGMENTATION_SUPPORTED
Jul/23/2019 15:54:17 ipsec 2222: (NAT-T) REMOTE
Jul/23/2019 15:54:17 ipsec 2222: KA list add: 122.96.77.59[4500]->122.96.40.70[14967]
Jul/23/2019 15:54:17 ipsec,debug 2222: ===== received 524 bytes from 122.96.40.70[58605] to 122.96.77.59[4500]
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 65c3d6b0 5a805900 24ec6cab 97a8445c 2e202308 00000001 0000020c 230001f0
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: b17f584a c60f41e9 7dc3c87c 6b88af7f a9cdf787 7b44ea0e 324aaf81 e7cb8248
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: f908d8ff 029e7b74 dc4d93aa 17d81bc9 eac97ef5 e34ccaf0 c5e53a23 43934714
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: c62f5346 d5bd4ec6 318b2dd5 d30f1d45 a60b2775 54a9bf98 d86c6da9 124cfaaa
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: e926730f 68dd3e39 8b154755 305dd46d 386c8315 0442a884 48ab5e38 14cb000c
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 43c28963 36a65593 67cff8ec f518112b 2002686a ded7ce94 6b6d843c c0fd7e1d
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: d38c3814 7d94b004 4ced736b 23435044 f036bdb0 ba06ee2b 5b724fd9 e6140a61
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 7f139080 d175f91c 619afd72 22eac481 db360526 08761bab ad394f6e 25a8e6e1
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: be0750f3 61caacee cc2172d6 cc4a9f6d 0e5fdbdf 855fe906 dbdc6b29 09c14e44
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 2d3179b4 d72c2513 ed7f129e 934adef4 07b1e093 5c32842a ea529d6c 6322d9d5
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 3cf960aa 65e4e509 70dbd628 acdcd6c2 94e656c0 44d9094f 25199258 6d2bf2d9
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: cceca636 97a0f17c 17da07ce 40c0829f a9e8f2ce 9666b759 2f619398 38ecfda1
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: f6690408 517cda87 8e8d44a9 377f32d8 bcd85c5e a05eb297 178969b9 1a7a3120
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 6bc1957c 3ba8597d 765b0d3b 86228160 2fd79d75 6a019eb2 8d1ec559 3b57f300
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 53edfd87 84680d35 541683aa b0f305a5 d92f9d61 6cfe9579 39a71f97 ab8c771f
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 4c90e932 89fe46ef 1fd6c083 ebb8dd71 624950b0 cc290227 bad287d8 cd4d330f
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 7044bd74 e0d5e961 c6570b3a
Jul/23/2019 15:54:17 ipsec 2222: -> ike2 request, exchange: AUTH:1 122.96.40.70[58605]
Jul/23/2019 15:54:17 ipsec 2222: peer ports changed: 14967 -> 58605
Jul/23/2019 15:54:17 ipsec 2222: KA remove: 122.96.77.59[4500]->122.96.40.70[14967]
Jul/23/2019 15:54:17 ipsec,debug 2222: KA tree dump: 122.96.77.59[4500]->122.96.40.70[14967] (in_use=1)
Jul/23/2019 15:54:17 ipsec,debug 2222: KA removing this one...
Jul/23/2019 15:54:17 ipsec 2222: KA list add: 122.96.77.59[4500]->122.96.40.70[58605]
Jul/23/2019 15:54:17 ipsec 2222: payload seen: ENC (496 bytes)
Jul/23/2019 15:54:17 ipsec 2222: processing payload: ENC
Jul/23/2019 15:54:17 ipsec,debug 2222: => iv (size 0x10)
Jul/23/2019 15:54:17 ipsec,debug 2222: b17f584a c60f41e9 7dc3c87c 6b88af7f
Jul/23/2019 15:54:17 ipsec,debug 2222: decrypted
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: => decrypted packet (size 0x1c1)
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 2900000c 01000000 0adf0e27 29000008 00004000 24000008 0000400c 2f000025
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 02000000 34306432 30326335 39663362 2e736e2e 6d796e65 746e616d 652e6e65
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 74290000 28010000 00000100 00000600 00000300 00000200 00000800 00000c00
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 00000a00 00001900 00290000 08000040 0a210000 08000040 0b2c0000 c8020000
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 28010304 030d3183 db030000 0c010000 0c800e01 00030000 08030000 0c000000
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 08050000 00020000 28020304 030b7890 69030000 0c010000 0c800e01 00030000
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 08030000 0c000000 08050000 00020000 28030304 0300428c 07030000 0c010000
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 0c800e01 00030000 08030000 0c000000 08050000 00020000 28040304 030984e9
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: fd030000 0c010000 0c800e00 80030000 08030000 02000000 08050000 00000000
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 24050304 0302d546 cf030000 08010000 03030000 08030000 02000000 08050000
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 002d0000 40020000 00070000 100000ff ff000000 00ffffff ff080000 280000ff
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: ff000000 00000000 00000000 00000000 00ffffff ffffffff ffffffff ffffffff
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: ff000000 40020000 00070000 100000ff ff000000 00ffffff ff080000 280000ff
Jul/23/2019 15:54:17 ipsec 2222: payload seen: ID_I (12 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: ID_R (37 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: CONFIG (40 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: SA (200 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: TS_I (64 bytes)
Jul/23/2019 15:54:17 ipsec 2222: payload seen: TS_R (64 bytes)
Jul/23/2019 15:54:17 ipsec 2222: notify: INITIAL_CONTACT
Jul/23/2019 15:54:17 ipsec 2222: notify: MOBIKE_SUPPORTED
Jul/23/2019 15:54:17 ipsec 2222: notify: ESP_TFC_PADDING_NOT_SUPPORTED
Jul/23/2019 15:54:17 ipsec 2222: notify: NON_FIRST_FRAGMENTS_ALSO
Jul/23/2019 15:54:17 ipsec 2222: ike auth: respond
Jul/23/2019 15:54:17 ipsec 2222: processing payload: ID_I
Jul/23/2019 15:54:17 ipsec 2222: ID_I (ADDR4): 10.223.14.39
Jul/23/2019 15:54:17 ipsec 2222: processing payload: ID_R
Jul/23/2019 15:54:17 ipsec 2222: ID_R (FQDN): MYSN.sn.mynetname.net
Jul/23/2019 15:54:17 ipsec 2222: processing payload: AUTH (not found)
Jul/23/2019 15:54:17 ipsec 2222: requested server id: MYSN.sn.mynetname.net
Jul/23/2019 15:54:17 ipsec,error 2222: identity not found for server:MYSN.sn.mynetname.net peer: ADDR4: 10.223.14.39
Jul/23/2019 15:54:17 ipsec 2222: reply notify: AUTHENTICATION_FAILED
Jul/23/2019 15:54:17 ipsec 2222: adding notify: AUTHENTICATION_FAILED
Jul/23/2019 15:54:17 ipsec,debug 2222: => (size 0x8)
Jul/23/2019 15:54:17 ipsec,debug 2222: 00000008 00000018
Jul/23/2019 15:54:17 ipsec 2222: <- ike2 reply, exchange: AUTH:1 122.96.40.70[58605]
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: => outgoing plain packet (size 0x24)
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 65c3d6b0 5a805900 24ec6cab 97a8445c 29202320 00000001 00000024 00000008
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 00000018
Jul/23/2019 15:54:17 ipsec 2222: adding payload: ENC
Jul/23/2019 15:54:17 ipsec,debug 2222: => (size 0xd0)
Jul/23/2019 15:54:17 ipsec,debug 2222: 290000d0 cd4d330f 7044bd74 e0d5e961 c6570b3a 5f7d59c9 eca3a416 c86bc3bf
Jul/23/2019 15:54:17 ipsec,debug 2222: 81d1fbfb e4d5544b 01d046df 2ea09cda c14be49c e0469698 961e6aa2 910e0af4
Jul/23/2019 15:54:17 ipsec,debug 2222: fadebcd9 db650aa0 1d0faf4b 8cc0bdb7 fe27d0c0 bac0817c 522dca90 e716a354
Jul/23/2019 15:54:17 ipsec,debug 2222: 8c0da009 6b5eb8ad c26f9288 490eb7b3 38674766 6986bf1a 7feeb4e8 e863eeda
Jul/23/2019 15:54:17 ipsec,debug 2222: cab3552e 90a7a4dd b2a768b5 b06ad328 363195dc 699cd0f9 745f8825 6767eb8b
Jul/23/2019 15:54:17 ipsec,debug 2222: 4e1a705d f873a580 6c13b085 7e40ad6c 8397dc8e bad97864 87034c12 f41e79a6
Jul/23/2019 15:54:17 ipsec,debug 2222: 6fe55f40 00000000 00000000 00000000
Jul/23/2019 15:54:17 ipsec,debug 2222: ===== sending 236 bytes from 122.96.77.59[4500] to 122.96.40.70[58605]
Jul/23/2019 15:54:17 ipsec,debug 2222: 1 times of 240 bytes message will be sent to 122.96.40.70[58605]
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 65c3d6b0 5a805900 24ec6cab 97a8445c 2e202320 00000001 000000ec 290000d0
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: cd4d330f 7044bd74 e0d5e961 c6570b3a 5f7d59c9 eca3a416 c86bc3bf 81d1fbfb
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: e4d5544b 01d046df 2ea09cda c14be49c e0469698 961e6aa2 910e0af4 fadebcd9
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: db650aa0 1d0faf4b 8cc0bdb7 fe27d0c0 bac0817c 522dca90 e716a354 8c0da009
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 6b5eb8ad c26f9288 490eb7b3 38674766 6986bf1a 7feeb4e8 e863eeda cab3552e
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 90a7a4dd b2a768b5 b06ad328 363195dc 699cd0f9 745f8825 6767eb8b 4e1a705d
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: f873a580 6c13b085 7e40ad6c 8397dc8e bad97864 87034c12 f41e79a6 6fe55f40
Jul/23/2019 15:54:17 ipsec,debug,packet 2222: 229baefb d966366f 706beee4
Jul/23/2019 15:54:17 ipsec,info 2222: killing ike2 SA: 122.96.77.59[4500]-122.96.40.70[58605] spi:24ec6cab97a8445c:65c3d6b05a805900
Jul/23/2019 15:54:17 ipsec 2222: KA remove: 122.96.77.59[4500]->122.96.40.70[58605]
Jul/23/2019 15:54:17 ipsec,debug 2222: KA tree dump: 122.96.77.59[4500]->122.96.40.70[58605] (in_use=1)
Jul/23/2019 15:54:29 ipsec,debug 2222: ===== received 604 bytes from 122.96.40.70[14967] to 122.96.77.59[500]
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 0c7e6427 fbef14ca 00000000 00000000 21202208 00000000 0000025c 220000dc
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 0200002c 01010004 0300000c 0100000c 800e0100 03000008 02000005 03000008
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 0300000c 00000008 0400000e 0200002c 02010004 0300000c 0100000c 800e0100
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 03000008 02000005 03000008 0300000c 00000008 04000013 0200002c 03010004
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 0300000c 0100000c 800e0100 03000008 02000005 03000008 0300000c 00000008
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 04000005 0200002c 04010004 0300000c 0100000c 800e0080 03000008 02000002
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 03000008 03000002 00000008 04000002 00000028 05010004 03000008 01000003
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 03000008 02000002 03000008 03000002 00000008 04000002 28000108 000e0000
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 2af4d04e 3163b42e ea63a41a 2c385c98 672ac7f7 d025d640 ea1fcb61 0d186f43
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: e6dee07e 8aa688e9 9a8e055c 64b7b079 68fa1efd b776f775 3412a98b 917793e2
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: be27fea2 b2361d53 8777af50 f347b075 6450a093 dcf6c68b 7e4b7f03 5c1cae3d
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 5e58ab2f ae208239 53d6c7cf b85d2c23 04d3b4ca 05306c0b 4515ae91 084de935
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 8306f3b5 f8f0ed85 6cd39e26 1bdca4dd 4fc27a3a ef0dcaa6 707719c0 6065b913
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: e92573a0 ba270d51 678433ea 95260fe7 7f8ff2be 234990ca 49c1aec0 e7489003
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 7d2beb3b efd7de08 212c42c9 55be5b90 dea6a571 8d92fc24 06f1d4f0 1e8bf140
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 96c4c165 db8d32de 10c0b102 741b4897 96466806 9a60d251 4558f615 ce78b7eb
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 29000014 aff72d23 52d52041 f792f436 a3ce6866 29000008 00004016 2900001c
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 00004004 bfd8157d 829a2e9b b4b49870 9bb30c9f 9a22e326 2900001c 00004005
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 6605de03 8cb74913 b99ce09a b427989f 3eea86ec 00000008 0000402e
Jul/23/2019 15:54:29 ipsec 2222: -> ike2 request, exchange: SA_INIT:0 122.96.40.70[14967]
Jul/23/2019 15:54:29 ipsec 2222: ike2 respond
Jul/23/2019 15:54:29 ipsec 2222: payload seen: SA (220 bytes)
Jul/23/2019 15:54:29 ipsec 2222: payload seen: KE (264 bytes)
Jul/23/2019 15:54:29 ipsec 2222: payload seen: NONCE (20 bytes)
Jul/23/2019 15:54:29 ipsec 2222: payload seen: NOTIFY (8 bytes)
Jul/23/2019 15:54:29 ipsec 2222: payload seen: NOTIFY (28 bytes)
Jul/23/2019 15:54:29 ipsec 2222: processing payload: NONCE
Jul/23/2019 15:54:29 ipsec 2222: processing payload: SA
Jul/23/2019 15:54:29 ipsec 2222: IKE Protocol: IKE
Jul/23/2019 15:54:29 ipsec 2222: proposal #1
Jul/23/2019 15:54:29 ipsec 2222: enc: aes256-cbc
Jul/23/2019 15:54:29 ipsec 2222: prf: hmac-sha256
Jul/23/2019 15:54:29 ipsec 2222: auth: sha256
Jul/23/2019 15:54:29 ipsec 2222: dh: modp2048
Jul/23/2019 15:54:29 ipsec 2222: proposal #2
Jul/23/2019 15:54:29 ipsec 2222: dh: ecp256
Jul/23/2019 15:54:29 ipsec 2222: proposal #3
Jul/23/2019 15:54:29 ipsec 2222: dh: modp1536
Jul/23/2019 15:54:29 ipsec 2222: proposal #4
Jul/23/2019 15:54:29 ipsec 2222: enc: aes128-cbc
Jul/23/2019 15:54:29 ipsec 2222: prf: hmac-sha1
Jul/23/2019 15:54:29 ipsec 2222: auth: sha1
Jul/23/2019 15:54:29 ipsec 2222: dh: modp1024
Jul/23/2019 15:54:29 ipsec 2222: proposal #5
Jul/23/2019 15:54:29 ipsec 2222: enc: 3des-cbc
Jul/23/2019 15:54:29 ipsec 2222: matched proposal:
Jul/23/2019 15:54:29 ipsec 2222: processing payload: KE
Jul/23/2019 15:54:29 ipsec 2222: DH group number mismatch: 2 != 14
Jul/23/2019 15:54:29 ipsec 2222: adding notify: INVALID_KE_PAYLOAD
Jul/23/2019 15:54:29 ipsec,debug 2222: => (size 0xa)
Jul/23/2019 15:54:29 ipsec,debug 2222: 0000000a 00000011 0002
Jul/23/2019 15:54:29 ipsec,debug 2222: ===== sending 38 bytes from 122.96.77.59[500] to 122.96.40.70[14967]
Jul/23/2019 15:54:29 ipsec,debug 2222: 1 times of 38 bytes message will be sent to 122.96.40.70[14967]
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 0c7e6427 fbef14ca 00000000 00000000 29202220 00000000 00000026 0000000a
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 00000011 0002
Jul/23/2019 15:54:29 ipsec,debug 2222: ===== received 476 bytes from 122.96.40.70[14967] to 122.96.77.59[500]
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 0c7e6427 fbef14ca 00000000 00000000 21202208 00000000 000001dc 220000dc
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 03000008 02000002 03000008 03000002 00000008 04000002 28000088 00020000
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 50a58065 d24b5db6 05039c4b e20427d3 2c006b9f abb437ed 101284d9 902a0079
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 27643469 8142fbf4 9493dd6d 5b24510d 7d3604d0 ff1e23ce 4d5d8d44 abfa570d
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 12c92211 63183b00 7008a8cd 2060ac95 76f12107 b7051427 23f888a5 06501000
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 2c1350a8 2317af4f 64a2a688 cd6cef53 0ae681a7 08552962 bdb4ebca f9bf094b
Jul/23/2019 15:54:29 ipsec,debug,packet 2222: 29000014 4d559d8a f71a3ea2 41523062 a8fd8a89 29000008 00004016 2900001c
Jul/23/2019 15:54:29 ipsec 2222: payload seen: KE (136 bytes)
Jul/23/2019 15:54:30 ipsec,debug 2222: => shared secret (size 0x80)
Jul/23/2019 15:54:30 ipsec,debug 2222: 83478db7 3a046baf 4a504c43 1fdd6334 6d7953e6 7312278e ab304678 22af6e4f
Jul/23/2019 15:54:30 ipsec,debug 2222: 3f47b838 7994beef c2e78085 e6d48f8a 2cdec9d0 4b3cf889 198fc4e4 58422693
Jul/23/2019 15:54:30 ipsec,debug 2222: 6cd00613 24c49826 9ef767ed 6b5bf9d3 f084ce13 30ccaad8 ddd32669 52fd53de
Jul/23/2019 15:54:30 ipsec,debug 2222: 8e42da2c fdf112c6 e541144b d6a94a38 18667c41 70c626b3 137ba41b 37a304a8
Jul/23/2019 15:54:30 ipsec 2222: adding payload: SA
Jul/23/2019 15:54:30 ipsec,debug 2222: => (size 0x30)
Jul/23/2019 15:54:30 ipsec,debug 2222: 00000030 0000002c 01010004 0300000c 0100000c 800e0080 03000008 02000002
Jul/23/2019 15:54:30 ipsec,debug 2222: 03000008 03000002 00000008 04000002
Jul/23/2019 15:54:30 ipsec 2222: adding payload: KE
Jul/23/2019 15:54:30 ipsec,debug 2222: => (size 0x88)
Jul/23/2019 15:54:30 ipsec,debug 2222: 00000088 00020000 a989c1a4 a2bfe0c0 4a442b12 3a2f699a 2ba52a67 5fc6aed1
Jul/23/2019 15:54:30 ipsec,debug 2222: 12b52c26 45763477 8e1d02b1 4fe65005 fcfd1cf0 69ee19b3 13998367 2ef9de0b
Jul/23/2019 15:54:30 ipsec,debug 2222: ce4a0c09 08c5e94d fd245649 5e23653e 678c07d9 ac0bdc1c 91f3ed2e 132daee8
Jul/23/2019 15:54:30 ipsec,debug 2222: 1b2e69f8 fd22e8c3 f8ab0472 68522760 765901bc 8a593bee ac67f4de b2d6efec
Jul/23/2019 15:54:30 ipsec,debug 2222: 74a57144 c3501d21
Jul/23/2019 15:54:30 ipsec 2222: adding payload: NONCE
Jul/23/2019 15:54:30 ipsec,debug 2222: => (size 0x1c)
Jul/23/2019 15:54:30 ipsec,debug 2222: 0000001c 3fbcbf84 5f788536 34598bea c4e48dd9 39e98fa5 92a99c36
Jul/23/2019 15:54:30 ipsec 2222: adding notify: NAT_DETECTION_SOURCE_IP
Jul/23/2019 15:54:30 ipsec,debug 2222: 0000001c 00004004 35de7e0b 3e51b08c 378e93b9 e1e67668 60976a38
Jul/23/2019 15:54:30 ipsec 2222: adding notify: NAT_DETECTION_DESTINATION_IP
Jul/23/2019 15:54:30 ipsec,debug 2222: 0000001c 00004005 575d04b4 32aece23 1d11f8c3 894334fb 64e91036
Jul/23/2019 15:54:30 ipsec 2222: adding payload: CERTREQ
Jul/23/2019 15:54:30 ipsec,debug 2222: => (size 0x5)
Jul/23/2019 15:54:30 ipsec,debug 2222: 00000005 04
Jul/23/2019 15:54:30 ipsec 2222: <- ike2 reply, exchange: SA_INIT:0 122.96.40.70[14967]
Jul/23/2019 15:54:30 ipsec,debug 2222: ===== sending 301 bytes from 122.96.77.59[500] to 122.96.40.70[14967]
Jul/23/2019 15:54:30 ipsec,debug 2222: 1 times of 301 bytes message will be sent to 122.96.40.70[14967]
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 0c7e6427 fbef14ca 1fea886c 55b30690 21202220 00000000 0000012d 22000030
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 0000002c 01010004 0300000c 0100000c 800e0080 03000008 02000002 03000008
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 03000002 00000008 04000002 28000088 00020000 a989c1a4 a2bfe0c0 4a442b12
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 3a2f699a 2ba52a67 5fc6aed1 12b52c26 45763477 8e1d02b1 4fe65005 fcfd1cf0
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 69ee19b3 13998367 2ef9de0b ce4a0c09 08c5e94d fd245649 5e23653e 678c07d9
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: ac0bdc1c 91f3ed2e 132daee8 1b2e69f8 fd22e8c3 f8ab0472 68522760 765901bc
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 8a593bee ac67f4de b2d6efec 74a57144 c3501d21 2900001c 3fbcbf84 5f788536
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 34598bea c4e48dd9 39e98fa5 92a99c36 2900001c 00004004 35de7e0b 3e51b08c
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 378e93b9 e1e67668 60976a38 2600001c 00004005 575d04b4 32aece23 1d11f8c3
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 894334fb 64e91036 00000005 04
Jul/23/2019 15:54:30 ipsec,debug 2222: => skeyseed (size 0x14)
Jul/23/2019 15:54:30 ipsec,debug 2222: 9ab1db84 3514ef29 29f6210f d7506751 41af7f3e
Jul/23/2019 15:54:30 ipsec,debug 2222: => keymat (size 0x14)
Jul/23/2019 15:54:30 ipsec,debug 2222: 2d3b469e ef9cf493 e06b62f9 cd22490a 4e0ac984
Jul/23/2019 15:54:30 ipsec,debug 2222: => SK_ai (size 0x14)
Jul/23/2019 15:54:30 ipsec,debug 2222: fc9637e3 c6f3440f a52e3112 ee49b5e4 55f870d0
Jul/23/2019 15:54:30 ipsec,debug 2222: => SK_ar (size 0x14)
Jul/23/2019 15:54:30 ipsec,debug 2222: 8763fa8d ad461d9c 688885b4 736b9999 d4d0a7f3
Jul/23/2019 15:54:30 ipsec,debug 2222: => SK_ei (size 0x10)
Jul/23/2019 15:54:30 ipsec,debug 2222: 757a2a09 f15b10aa 41df5dcf 226db640
Jul/23/2019 15:54:30 ipsec,debug 2222: => SK_er (size 0x10)
Jul/23/2019 15:54:30 ipsec,debug 2222: 3fc4fc01 9a81ff66 03d6a55a 23b55b85
Jul/23/2019 15:54:30 ipsec,debug 2222: => SK_pi (size 0x14)
Jul/23/2019 15:54:30 ipsec,debug 2222: 528bb896 32a76ee7 dbce8131 df362757 c24e125f
Jul/23/2019 15:54:30 ipsec,debug 2222: => SK_pr (size 0x14)
Jul/23/2019 15:54:30 ipsec,debug 2222: 3cb68e80 4181c4b2 5656088c e4828ade e8007efc
Jul/23/2019 15:54:30 ipsec,info 2222: new ike2 SA (R): 122.96.77.59[500]-122.96.40.70[14967] spi:1fea886c55b30690:0c7e6427fbef14ca
Jul/23/2019 15:54:30 ipsec 2222: processing payloads: VID (none found)
Jul/23/2019 15:54:30 ipsec 2222: processing payloads: NOTIFY
Jul/23/2019 15:54:30 ipsec 2222: notify: REDIRECT_SUPPORTED
Jul/23/2019 15:54:30 ipsec 2222: notify: NAT_DETECTION_SOURCE_IP
Jul/23/2019 15:54:30 ipsec 2222: notify: NAT_DETECTION_DESTINATION_IP
Jul/23/2019 15:54:30 ipsec 2222: notify: IKEV2_FRAGMENTATION_SUPPORTED
Jul/23/2019 15:54:30 ipsec 2222: (NAT-T) REMOTE
Jul/23/2019 15:54:30 ipsec 2222: KA list add: 122.96.77.59[4500]->122.96.40.70[14967]
Jul/23/2019 15:54:30 ipsec,debug 2222: ===== received 524 bytes from 122.96.40.70[58605] to 122.96.77.59[4500]
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 0c7e6427 fbef14ca 1fea886c 55b30690 2e202308 00000001 0000020c 230001f0
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 8c1cc286 dcf67c1a 625f3a95 66fe8153 1a17bcdd 83d625a3 c09b0e9f ca4a2e49
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: c3717563 99905525 7103978b acf7ab14 69321c86 dea37ecc a400a38a a25f36c6
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 336d71cb 6e71ec4a c78983ad f28e126a 133e6642 ebcaf793 5a18dbbf baeddfa8
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 003dd642 7409697f 8e122cae d109b191 e520c55a ea3f99f8 dc95bb35 20ff6c53
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 3165103b 9f6578ca a7d77fc9 891f573e 8a68132e 42922e80 901a5f2e dd77be4a
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: b608c989 a673c59b b201afd3 f90de136 0047af31 beafa0df 7aa42a42 8ff3dfeb
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 9ca4f1c6 15696131 1d283354 b0c9420c 95759d4d 9a911f8a 7035b9da b614426b
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 66f0ad8d 32ed4f5e 26556332 fba7494c b0fef054 e040f5b8 ca17f097 d1da69b4
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 83d91043 c617790f 7f060933 9122451d 1d3a5ef9 86347f5f 5a8e0dc2 230069a4
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 9fbcf1d6 79564898 38407571 16d088af f805081b 28481647 95e2fafb 15ac1759
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 498757a1 d34fa2dd 69bd72ca 4469b40c ab310a8d baa35560 adc261e2 4ad8bab6
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: a0375579 f96d45e9 64a2c0ef 2799db9a ad134212 d7f2d8ae 3dd4990e b3c82862
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: d834a356 d8fa5968 aba13a2a a8a7cfd0 fab2fcae 4a8d63c7 e46bd247 95d0973f
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: a83174f7 45ecd5cb 39a776d9 dc927c14 f2151b32 aa09e1b5 a4dd1039 76b7108f
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: f3a5fb88 de8a7ffc bb5395cf 6a49375d 09354f69 9ee0673d c1d7e7b1 f6e8e6dc
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 417da4f9 1dc0b7b6 64aca380
Jul/23/2019 15:54:30 ipsec 2222: -> ike2 request, exchange: AUTH:1 122.96.40.70[58605]
Jul/23/2019 15:54:30 ipsec 2222: peer ports changed: 14967 -> 58605
Jul/23/2019 15:54:30 ipsec 2222: KA remove: 122.96.77.59[4500]->122.96.40.70[14967]
Jul/23/2019 15:54:30 ipsec,debug 2222: KA tree dump: 122.96.77.59[4500]->122.96.40.70[14967] (in_use=1)
Jul/23/2019 15:54:30 ipsec,debug 2222: KA removing this one...
Jul/23/2019 15:54:30 ipsec 2222: KA list add: 122.96.77.59[4500]->122.96.40.70[58605]
Jul/23/2019 15:54:30 ipsec 2222: payload seen: ENC (496 bytes)
Jul/23/2019 15:54:30 ipsec 2222: processing payload: ENC
Jul/23/2019 15:54:30 ipsec,debug 2222: => iv (size 0x10)
Jul/23/2019 15:54:30 ipsec,debug 2222: 8c1cc286 dcf67c1a 625f3a95 66fe8153
Jul/23/2019 15:54:30 ipsec,debug 2222: decrypted
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: => decrypted packet (size 0x1c1)
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 2900000c 01000000 0adf0e27 29000008 00004000 24000008 0000400c 2f000025
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 02000000 34306432 30326335 39663362 2e736e2e 6d796e65 746e616d 652e6e65
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 74290000 28010000 00000100 00000600 00000300 00000200 00000800 00000c00
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 00000a00 00001900 00290000 08000040 0a210000 08000040 0b2c0000 c8020000
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 28010304 030623c5 2f030000 0c010000 0c800e01 00030000 08030000 0c000000
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 08050000 00020000 28020304 0309351a 23030000 0c010000 0c800e01 00030000
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 08030000 0c000000 08050000 00020000 28030304 030295c8 53030000 0c010000
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 0c800e01 00030000 08030000 0c000000 08050000 00020000 28040304 030b15a7
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: d8030000 0c010000 0c800e00 80030000 08030000 02000000 08050000 00000000
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 24050304 030161ae 3c030000 08010000 03030000 08030000 02000000 08050000
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 002d0000 40020000 00070000 100000ff ff000000 00ffffff ff080000 280000ff
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: ff000000 00000000 00000000 00000000 00ffffff ffffffff ffffffff ffffffff
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: ff000000 40020000 00070000 100000ff ff000000 00ffffff ff080000 280000ff
Jul/23/2019 15:54:30 ipsec 2222: payload seen: ID_I (12 bytes)
Jul/23/2019 15:54:30 ipsec 2222: payload seen: NOTIFY (8 bytes)
Jul/23/2019 15:54:30 ipsec 2222: payload seen: ID_R (37 bytes)
Jul/23/2019 15:54:30 ipsec 2222: payload seen: CONFIG (40 bytes)
Jul/23/2019 15:54:30 ipsec 2222: payload seen: SA (200 bytes)
Jul/23/2019 15:54:30 ipsec 2222: payload seen: TS_I (64 bytes)
Jul/23/2019 15:54:30 ipsec 2222: payload seen: TS_R (64 bytes)
Jul/23/2019 15:54:30 ipsec 2222: notify: INITIAL_CONTACT
Jul/23/2019 15:54:30 ipsec 2222: notify: MOBIKE_SUPPORTED
Jul/23/2019 15:54:30 ipsec 2222: notify: ESP_TFC_PADDING_NOT_SUPPORTED
Jul/23/2019 15:54:30 ipsec 2222: notify: NON_FIRST_FRAGMENTS_ALSO
Jul/23/2019 15:54:30 ipsec 2222: ike auth: respond
Jul/23/2019 15:54:30 ipsec 2222: processing payload: ID_I
Jul/23/2019 15:54:30 ipsec 2222: ID_I (ADDR4): 10.223.14.39
Jul/23/2019 15:54:30 ipsec 2222: processing payload: ID_R
Jul/23/2019 15:54:30 ipsec 2222: ID_R (FQDN): MYSN.sn.mynetname.net
Jul/23/2019 15:54:30 ipsec 2222: processing payload: AUTH (not found)
Jul/23/2019 15:54:30 ipsec 2222: requested server id: MYSN.sn.mynetname.net
Jul/23/2019 15:54:30 ipsec,error 2222: identity not found for server:MYSN.sn.mynetname.net peer: ADDR4: 10.223.14.39
Jul/23/2019 15:54:30 ipsec 2222: reply notify: AUTHENTICATION_FAILED
Jul/23/2019 15:54:30 ipsec 2222: adding notify: AUTHENTICATION_FAILED
Jul/23/2019 15:54:30 ipsec,debug 2222: => (size 0x8)
Jul/23/2019 15:54:30 ipsec,debug 2222: 00000008 00000018
Jul/23/2019 15:54:30 ipsec 2222: <- ike2 reply, exchange: AUTH:1 122.96.40.70[58605]
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: => outgoing plain packet (size 0x24)
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 0c7e6427 fbef14ca 1fea886c 55b30690 29202320 00000001 00000024 00000008
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 00000018
Jul/23/2019 15:54:30 ipsec 2222: adding payload: ENC
Jul/23/2019 15:54:30 ipsec,debug 2222: => (size 0xd0)
Jul/23/2019 15:54:30 ipsec,debug 2222: 290000d0 f6e8e6dc 417da4f9 1dc0b7b6 64aca380 b04d853b 83301a12 dfe6bb26
Jul/23/2019 15:54:30 ipsec,debug 2222: a2402084 bdf4c305 ebff85f6 e86493c4 4735cf82 57ce83a8 db1baeac e7a859d5
Jul/23/2019 15:54:30 ipsec,debug 2222: 202c9992 629c45f1 d85b1eeb abcf7a07 25aaa219 2a16a20e 2a624f49 6d676e74
Jul/23/2019 15:54:30 ipsec,debug 2222: 16426f79 e519f7f0 3c56f84c 9ff11837 69f016c3 a291ffe1 bd0ef865 90332390
Jul/23/2019 15:54:30 ipsec,debug 2222: 66697229 7b108f0d 46daec1c 01d9a04a db82db9e faa42827 20ef3de8 df1fd21d
Jul/23/2019 15:54:30 ipsec,debug 2222: 177c5907 eac9d268 24356b86 d43ea780 4b68b43f 182deed2 ebf0bbe0 d1d8190f
Jul/23/2019 15:54:30 ipsec,debug 2222: ff0acee4 00000000 00000000 00000000
Jul/23/2019 15:54:30 ipsec,debug 2222: ===== sending 236 bytes from 122.96.77.59[4500] to 122.96.40.70[58605]
Jul/23/2019 15:54:30 ipsec,debug 2222: 1 times of 240 bytes message will be sent to 122.96.40.70[58605]
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 0c7e6427 fbef14ca 1fea886c 55b30690 2e202320 00000001 000000ec 290000d0
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: f6e8e6dc 417da4f9 1dc0b7b6 64aca380 b04d853b 83301a12 dfe6bb26 a2402084
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: bdf4c305 ebff85f6 e86493c4 4735cf82 57ce83a8 db1baeac e7a859d5 202c9992
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 629c45f1 d85b1eeb abcf7a07 25aaa219 2a16a20e 2a624f49 6d676e74 16426f79
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: e519f7f0 3c56f84c 9ff11837 69f016c3 a291ffe1 bd0ef865 90332390 66697229
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 7b108f0d 46daec1c 01d9a04a db82db9e faa42827 20ef3de8 df1fd21d 177c5907
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: eac9d268 24356b86 d43ea780 4b68b43f 182deed2 ebf0bbe0 d1d8190f ff0acee4
Jul/23/2019 15:54:30 ipsec,debug,packet 2222: 7c173ee2 cc65e971 5fc50ed1
Jul/23/2019 15:54:30 ipsec,info 2222: killing ike2 SA: 122.96.77.59[4500]-122.96.40.70[58605] spi:1fea886c55b30690:0c7e6427fbef14ca
Jul/23/2019 15:54:30 ipsec 2222: KA remove: 122.96.77.59[4500]->122.96.40.70[58605]
Jul/23/2019 15:54:30 ipsec,debug 2222: KA tree dump: 122.96.77.59[4500]->122.96.40.70[58605] (in_use=1)
Jul/23/2019 15:59:36 ipsec,debug 2222: ===== received 604 bytes from 122.96.40.70[14968] to 122.96.77.59[500]
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 5ae15859 e20ce140 00000000 00000000 21202208 00000000 0000025c 220000dc
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 0200002c 01010004 0300000c 0100000c 800e0100 03000008 02000005 03000008
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 0300000c 00000008 0400000e 0200002c 02010004 0300000c 0100000c 800e0100
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 03000008 02000005 03000008 0300000c 00000008 04000013 0200002c 03010004
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 0300000c 0100000c 800e0100 03000008 02000005 03000008 0300000c 00000008
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 04000005 0200002c 04010004 0300000c 0100000c 800e0080 03000008 02000002
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 03000008 03000002 00000008 04000002 00000028 05010004 03000008 01000003
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 03000008 02000002 03000008 03000002 00000008 04000002 28000108 000e0000
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 99722c07 62616352 4a921f5b b0296fad 64a906bd 30755378 ab6397ce 1f86a5a1
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: d837e132 c2ca0155 6f2b123d a194f8ba 3d59d852 416420f4 e0c1febf 1e89a6e7
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 4e8f1fc8 ed36dd52 37b5e0d0 52175550 fe8561ee 91397972 7c366d78 84781dc4
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: e4b0f48e 6930ed9c 8f5a6bfe 4ef2fe5b ed6effd2 55e404e8 0fc4cac4 dea4a29f
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: c15da442 f08ff006 b62bece3 bb398e29 dcb21db5 8ee34e6a 89edeffb 19dd4337
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: da7cebbf 5cb77480 b08f637b 5d630a5b 52ebde69 27b44611 b1ff107c 2833c4ee
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 682ea61e be34a614 dd4732eb a148a929 9c0869ce 2907a0af 6ff0a073 3afc85d7
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 6088585e 3acde3ba d203490a 7f0b713d 824a54d6 2e07acdf 0654bd62 9ca581cf
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 29000014 cad7a1b1 dc0455ba bd8864fc e149e15e 29000008 00004016 2900001c
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 00004004 e420ee8d 654ace3d 1c23fe3f 2958b2f4 8ba1f9a5 2900001c 00004005
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 9c20b2cd f7409b34 ebf52937 4f6c263a 9beb6799 00000008 0000402e
Jul/23/2019 15:59:36 ipsec 2222: -> ike2 request, exchange: SA_INIT:0 122.96.40.70[14968]
Jul/23/2019 15:59:36 ipsec 2222: ike2 respond
Jul/23/2019 15:59:36 ipsec 2222: payload seen: SA (220 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: KE (264 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: NONCE (20 bytes)
Jul/23/2019 15:59:36 ipsec 2222: payload seen: NOTIFY (28 bytes)
Jul/23/2019 15:59:36 ipsec 2222: processing payload: NONCE
Jul/23/2019 15:59:36 ipsec 2222: processing payload: SA
Jul/23/2019 15:59:36 ipsec 2222: IKE Protocol: IKE
Jul/23/2019 15:59:36 ipsec 2222: proposal #1
Jul/23/2019 15:59:36 ipsec 2222: enc: aes256-cbc
Jul/23/2019 15:59:36 ipsec 2222: prf: hmac-sha256
Jul/23/2019 15:59:36 ipsec 2222: auth: sha256
Jul/23/2019 15:59:36 ipsec 2222: dh: modp2048
Jul/23/2019 15:59:36 ipsec 2222: proposal #2
Jul/23/2019 15:59:36 ipsec 2222: dh: ecp256
Jul/23/2019 15:59:36 ipsec 2222: proposal #3
Jul/23/2019 15:59:36 ipsec 2222: dh: modp1536
Jul/23/2019 15:59:36 ipsec 2222: proposal #4
Jul/23/2019 15:59:36 ipsec 2222: enc: aes128-cbc
Jul/23/2019 15:59:36 ipsec 2222: prf: hmac-sha1
Jul/23/2019 15:59:36 ipsec 2222: auth: sha1
Jul/23/2019 15:59:36 ipsec 2222: dh: modp1024
Jul/23/2019 15:59:36 ipsec 2222: proposal #5
Jul/23/2019 15:59:36 ipsec 2222: enc: 3des-cbc
Jul/23/2019 15:59:36 ipsec 2222: matched proposal:
Jul/23/2019 15:59:36 ipsec 2222: processing payload: KE
Jul/23/2019 15:59:36 ipsec 2222: DH group number mismatch: 2 != 14
Jul/23/2019 15:59:36 ipsec 2222: adding notify: INVALID_KE_PAYLOAD
Jul/23/2019 15:59:36 ipsec,debug 2222: => (size 0xa)
Jul/23/2019 15:59:36 ipsec,debug 2222: 0000000a 00000011 0002
Jul/23/2019 15:59:36 ipsec,debug 2222: ===== sending 38 bytes from 122.96.77.59[500] to 122.96.40.70[14968]
Jul/23/2019 15:59:36 ipsec,debug 2222: 1 times of 38 bytes message will be sent to 122.96.40.70[14968]
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 5ae15859 e20ce140 00000000 00000000 29202220 00000000 00000026 0000000a
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 00000011 0002
Jul/23/2019 15:59:36 ipsec,debug 2222: ===== received 476 bytes from 122.96.40.70[14968] to 122.96.77.59[500]
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 5ae15859 e20ce140 00000000 00000000 21202208 00000000 000001dc 220000dc
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 03000008 02000002 03000008 03000002 00000008 04000002 28000088 00020000
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 7305d613 c2461997 f376fd39 17aafab8 6c32c4d6 a60be867 70a622bb 8edbd90c
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 204b846f 8d9a0d3e 2befe315 3d744bbc d29df8fd c87d9834 3c70d3a4 2fa4e2b2
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 3da5d3a0 b8c35074 3fdb826a eecfa07b 08f8a053 f1cd8d9b 55a99178 8a0826d5
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 961d5e72 06610b61 749a0ed1 5403ab0b a317d0f8 d0d693e7 0843a9b2 99fe288c
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 29000014 2688906d 07251188 70c6270c 18e969be 29000008 00004016 2900001c
Jul/23/2019 15:59:36 ipsec 2222: payload seen: KE (136 bytes)
Jul/23/2019 15:59:36 ipsec,debug 2222: => shared secret (size 0x80)
Jul/23/2019 15:59:36 ipsec,debug 2222: 2c0e6565 e6dfba3a 23be9de6 8d675ffb 3cc20165 2e22ef20 cac6cdf3 006fdef3
Jul/23/2019 15:59:36 ipsec,debug 2222: 413cf7ed 629d84c6 b0bad36b ba45f697 8d843afa 5b140555 e2a36db5 6cacb035
Jul/23/2019 15:59:36 ipsec,debug 2222: a93a93d1 fdacf41b 842083d8 3a386548 2b4cdfca 4048b50f 9a0f235e 58ad3504
Jul/23/2019 15:59:36 ipsec,debug 2222: 06fcbdcf 62df04e9 bd385936 75f5d7e7 75a54c4a e9133eb6 f24a16ba 0896dd0b
Jul/23/2019 15:59:36 ipsec 2222: adding payload: SA
Jul/23/2019 15:59:36 ipsec,debug 2222: => (size 0x30)
Jul/23/2019 15:59:36 ipsec,debug 2222: 00000030 0000002c 01010004 0300000c 0100000c 800e0080 03000008 02000002
Jul/23/2019 15:59:36 ipsec,debug 2222: 03000008 03000002 00000008 04000002
Jul/23/2019 15:59:36 ipsec 2222: adding payload: KE
Jul/23/2019 15:59:36 ipsec,debug 2222: => (size 0x88)
Jul/23/2019 15:59:36 ipsec,debug 2222: 00000088 00020000 f3a00bb5 523d68c2 3efa5e21 915078e8 8983a857 d99e05af
Jul/23/2019 15:59:36 ipsec,debug 2222: 49d17c1d f02115b0 4038771a 0cede092 2328e75e 820f40e2 34a6651b cf93882f
Jul/23/2019 15:59:36 ipsec,debug 2222: 3b5f1686 f89f3e90 ac1f5397 4652a9ac 7d533317 31ab5959 2efa2243 d7e42bb4
Jul/23/2019 15:59:36 ipsec,debug 2222: 6a173038 d8e85d04 b92ceec5 7a8e1b84 93bd2ac8 ce6bd442 72c3c0a1 0674a028
Jul/23/2019 15:59:36 ipsec,debug 2222: 056700c1 2cccbccb
Jul/23/2019 15:59:36 ipsec 2222: adding payload: NONCE
Jul/23/2019 15:59:36 ipsec,debug 2222: => (size 0x1c)
Jul/23/2019 15:59:36 ipsec,debug 2222: 0000001c a4e2bcd5 8256c0ba 85bf87ec 8048a845 85540207 3f90c5f6
Jul/23/2019 15:59:36 ipsec 2222: adding notify: NAT_DETECTION_SOURCE_IP
Jul/23/2019 15:59:36 ipsec,debug 2222: 0000001c 00004004 36fdb4c1 30eb6361 cd417aba 47aab144 2171ff01
Jul/23/2019 15:59:36 ipsec 2222: adding notify: NAT_DETECTION_DESTINATION_IP
Jul/23/2019 15:59:36 ipsec,debug 2222: 0000001c 00004005 0c661144 2336b4b7 0d2d1cef c2abd61a 1e720eae
Jul/23/2019 15:59:36 ipsec 2222: adding payload: CERTREQ
Jul/23/2019 15:59:36 ipsec,debug 2222: => (size 0x5)
Jul/23/2019 15:59:36 ipsec,debug 2222: 00000005 04
Jul/23/2019 15:59:36 ipsec 2222: <- ike2 reply, exchange: SA_INIT:0 122.96.40.70[14968]
Jul/23/2019 15:59:36 ipsec,debug 2222: ===== sending 301 bytes from 122.96.77.59[500] to 122.96.40.70[14968]
Jul/23/2019 15:59:36 ipsec,debug 2222: 1 times of 301 bytes message will be sent to 122.96.40.70[14968]
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 5ae15859 e20ce140 e6ee4571 27604ba6 21202220 00000000 0000012d 22000030
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 0000002c 01010004 0300000c 0100000c 800e0080 03000008 02000002 03000008
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 03000002 00000008 04000002 28000088 00020000 f3a00bb5 523d68c2 3efa5e21
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 915078e8 8983a857 d99e05af 49d17c1d f02115b0 4038771a 0cede092 2328e75e
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 820f40e2 34a6651b cf93882f 3b5f1686 f89f3e90 ac1f5397 4652a9ac 7d533317
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 31ab5959 2efa2243 d7e42bb4 6a173038 d8e85d04 b92ceec5 7a8e1b84 93bd2ac8
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: ce6bd442 72c3c0a1 0674a028 056700c1 2cccbccb 2900001c a4e2bcd5 8256c0ba
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 85bf87ec 8048a845 85540207 3f90c5f6 2900001c 00004004 36fdb4c1 30eb6361
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: cd417aba 47aab144 2171ff01 2600001c 00004005 0c661144 2336b4b7 0d2d1cef
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: c2abd61a 1e720eae 00000005 04
Jul/23/2019 15:59:36 ipsec,debug 2222: => skeyseed (size 0x14)
Jul/23/2019 15:59:36 ipsec,debug 2222: da347abc 3e666c09 c3ccf05a f34bb3fc 194da637
Jul/23/2019 15:59:36 ipsec,debug 2222: => keymat (size 0x14)
Jul/23/2019 15:59:36 ipsec,debug 2222: 0b5c1979 a4e5002a 65b0830f 13dc1218 3cf5f5c5
Jul/23/2019 15:59:36 ipsec,debug 2222: => SK_ai (size 0x14)
Jul/23/2019 15:59:36 ipsec,debug 2222: 1eeaa80b 233914d6 83d98177 78eca61c 772da840
Jul/23/2019 15:59:36 ipsec,debug 2222: => SK_ar (size 0x14)
Jul/23/2019 15:59:36 ipsec,debug 2222: f208c44f 793f2f78 5de36812 3cd8a2af 8fcef95b
Jul/23/2019 15:59:36 ipsec,debug 2222: => SK_ei (size 0x10)
Jul/23/2019 15:59:36 ipsec,debug 2222: f30b200f 3fee13b0 e9dece63 6a9b810b
Jul/23/2019 15:59:36 ipsec,debug 2222: => SK_er (size 0x10)
Jul/23/2019 15:59:36 ipsec,debug 2222: 7cb761c3 e4f7e989 3e97196c f0dfe709
Jul/23/2019 15:59:36 ipsec,debug 2222: => SK_pi (size 0x14)
Jul/23/2019 15:59:36 ipsec,debug 2222: c603544e 5a7ac540 82465497 36568a86 486aa8f1
Jul/23/2019 15:59:36 ipsec,debug 2222: => SK_pr (size 0x14)
Jul/23/2019 15:59:36 ipsec,debug 2222: 6cfed4c0 7f3f3c53 443d194f 1de6aa30 9743f215
Jul/23/2019 15:59:36 ipsec,info 2222: new ike2 SA (R): 122.96.77.59[500]-122.96.40.70[14968] spi:e6ee457127604ba6:5ae15859e20ce140
Jul/23/2019 15:59:36 ipsec 2222: processing payloads: VID (none found)
Jul/23/2019 15:59:36 ipsec 2222: notify: REDIRECT_SUPPORTED
Jul/23/2019 15:59:36 ipsec 2222: notify: NAT_DETECTION_SOURCE_IP
Jul/23/2019 15:59:36 ipsec 2222: notify: NAT_DETECTION_DESTINATION_IP
Jul/23/2019 15:59:36 ipsec 2222: notify: IKEV2_FRAGMENTATION_SUPPORTED
Jul/23/2019 15:59:36 ipsec 2222: (NAT-T) REMOTE
Jul/23/2019 15:59:36 ipsec 2222: KA list add: 122.96.77.59[4500]->122.96.40.70[14968]
Jul/23/2019 15:59:36 ipsec,debug 2222: ===== received 524 bytes from 122.96.40.70[58612] to 122.96.77.59[4500]
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 5ae15859 e20ce140 e6ee4571 27604ba6 2e202308 00000001 0000020c 230001f0
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: b493e8a5 554b1ebc ae163d54 b648ebe7 bed94500 41ef3d61 e6ac72c1 2f271388
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 99ff3579 9314c0fc d5801949 13080497 bc251777 c1e6b4a4 2dcd8297 bd7d3cee
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: a2c759e6 c877cb74 0d345944 40de89e6 dbcec180 5b3dbb77 d1a7dfb3 86c59e82
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 84f2cfb4 a1f970bf 5e28578a d61689cb 0419237a 7c132be2 4be1be2e cff2eb91
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 6c2285db 46faf709 a90045d0 d62ee3b4 5a0eafa5 cead5f8b 52065271 c4505320
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 63dc227d 74344828 fc28c0df 1408a5b3 090c5546 438d0479 f6422332 56f52f78
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 2b51d4a0 a094f6be ea27cb82 5e1b374e ff7fe87d 7808ba15 99d75168 da1449dd
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 6f54d27d f312e5ac dea6603f 577c2e96 c9f5b763 ea0cbbda e7604a97 37cea8f3
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: b14f4aaa bf8020fb 1d435131 f686f7da 097087e3 fb4a5acf a27998ef 1a1d8066
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 9bac4207 e38dbba6 ba5dab5b a51b7625 a4133cd6 452d8f3c a95e0bd4 2fba3643
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: cc867550 541ad450 4155f339 99e9f84a 80d73de8 ca827cd7 141039db 3ab623f9
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 3e907481 d8fb7e95 c32fefa9 cb57e063 e68324b9 97a9005a 573df9b4 1fe4196e
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 03e368d4 58b8f338 73bf9ec0 13f5d4af 5af3415e 46537744 5ba479cd 11f74e73
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: f397e0e7 f26a20bf 3a51a4c9 c6daab61 1ef6a441 e59f13a6 1506ef9a fc8834ce
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: ab14fa35 426587c6 7427e212 ddbc9d0f 940b5c73 10f23cc0 f87fecd9 c226e846
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 7df24a02 3a676c57 0969b14c
Jul/23/2019 15:59:36 ipsec 2222: -> ike2 request, exchange: AUTH:1 122.96.40.70[58612]
Jul/23/2019 15:59:36 ipsec 2222: peer ports changed: 14968 -> 58612
Jul/23/2019 15:59:36 ipsec 2222: KA remove: 122.96.77.59[4500]->122.96.40.70[14968]
Jul/23/2019 15:59:36 ipsec,debug 2222: KA tree dump: 122.96.77.59[4500]->122.96.40.70[14968] (in_use=1)
Jul/23/2019 15:59:36 ipsec,debug 2222: KA removing this one...
Jul/23/2019 15:59:36 ipsec 2222: KA list add: 122.96.77.59[4500]->122.96.40.70[58612]
Jul/23/2019 15:59:36 ipsec 2222: payload seen: ENC (496 bytes)
Jul/23/2019 15:59:36 ipsec 2222: processing payload: ENC
Jul/23/2019 15:59:36 ipsec,debug 2222: => iv (size 0x10)
Jul/23/2019 15:59:36 ipsec,debug 2222: b493e8a5 554b1ebc ae163d54 b648ebe7
Jul/23/2019 15:59:36 ipsec,debug 2222: decrypted
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: => decrypted packet (size 0x1c1)
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 2900000c 01000000 0adf0e27 29000008 00004000 24000008 0000400c 2f000025
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 02000000 34306432 30326335 39663362 2e736e2e 6d796e65 746e616d 652e6e65
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 74290000 28010000 00000100 00000600 00000300 00000200 00000800 00000c00
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 00000a00 00001900 00290000 08000040 0a210000 08000040 0b2c0000 c8020000
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 28010304 0309ec19 bf030000 0c010000 0c800e01 00030000 08030000 0c000000
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 08050000 00020000 28020304 0305e250 9c030000 0c010000 0c800e01 00030000
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 08030000 0c000000 08050000 00020000 28030304 0307b6f0 66030000 0c010000
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 0c800e01 00030000 08030000 0c000000 08050000 00020000 28040304 0306ccd4
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: c5030000 0c010000 0c800e00 80030000 08030000 02000000 08050000 00000000
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 24050304 03087e24 06030000 08010000 03030000 08030000 02000000 08050000
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: 002d0000 40020000 00070000 100000ff ff000000 00ffffff ff080000 280000ff
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: ff000000 00000000 00000000 00000000 00ffffff ffffffff ffffffff ffffffff
Jul/23/2019 15:59:36 ipsec,debug,packet 2222: ff000000 40020000 00070000 100000ff ff000000 00ffffff ff080000 280000ff
Jul/23/2019 15:59:36 ipsec,error 2222: identity not found for server:MYSN.sn.mynetname.net peer: ADDR4: 10.223.14.39
Users browsing this forum: Bing [Bot] and 42 guests
