ab130kd
Mac telnet problem after upgrade... wrong password
Wed Jul 24, 2019 12:31 pm
after Upgrade, if i try to enter on a CPE mikrotik via mac-telnet the response is always:
"Login failed, incorrect username or password
Connection closed"
If i use IP, first time tell wrong password, second time I can enter.
The problem occured after upgrade 6.45.xx .
I try with winbox 3.19 but no solution..
Anybody has solution?
mrz
Re: Mac telnet problem after upgrade... wrong password
Wed Jul 24, 2019 12:35 pm
Mac telnet will not work if you try to telnet to device with installed older RouterOS (with old user store)
vohr56
Fri Aug 09, 2019 2:15 pm
Same problem here. RB750 Gr3 with 6.45.3 (Stable) installed and bootloader upgraded too. After upgrade, I reseted RB750 to defaults with "No Default Configuration" and "Do Not Backup" option marked and after reset I've lost access by mac-telnet from a CCR-1009 with v.6.42.6 that is connected directly to RB750. Same error that user ab130kd has:
Connection closed
It´s a bug on newer ROS versions, which did not happen on older versions.
Access from a PC with Winbox v3.19 by mac works normally.
mrz
Fri Aug 09, 2019 5:20 pm
see my post above.
You will not be able to connect from old ROS versions to 6.45.3
vohr56
Wed Aug 14, 2019 2:31 pm
Haaaaa, I don't believe! Is this informed in some changelog? I didn't see.
I think that this is bad, because is very difficult to maintain all MK in field updated. So, when some problem happens, very very problably mac-telnet will not work because probably MKs will have different ROS versions. Come on man! Bad, very bad...
Users browsing this forum: No registered users and 58 guests
