Technetium
Ovpn server on separate pool cannot reach lan
Thu Jul 25, 2019 5:13 pm
I've setup an OpenVPN server on my router.
My lan pool is 192.168.1.0/24, 192.168.1.1 is the bridge for the lan.
The OpenVPN pool is 10.255.255.0/24
The connection to the server works fine but i can't see and ping the lan
I've inserted the rule in the firewall to reach the lan from a open-vpn address pool but it not works. I cannot reach the lan 192.168.1.0/24.
add chain=forward src-address=192.168.1.0/24 dst-address=10.255.255.0/24 action=accept
add chain=forward src-address=10.255.255.0/24 dst-address=192.168.1.0/24 action=accept
OpenVPN client config is:
client
dev tun
proto tcp
remote MY_REMOTE_IP
port 1200
resolv-retry infinite
nobind
persist-key
persist-tun
tls-client
remote-cert-tls server
ca [inline]
cert [inline]
key [inline]
verb 4
keepalive 60 900
mute 10
cipher AES-256-CBC
auth SHA1
pull
auth-user-pass
auth-nocache
My router config:
add admin-mac=4C:5E:0C:07:63:3C arp=proxy-arp auto-mac=no comment=defconf \
    name=bridge
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full arp=proxy-arp \
    name=WAN1
set [ find default-name=ether5 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=WAN2
set [ find default-name=ether2 ] advertise=\
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4 ] advertise=\
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-b/g/n country=italy \
    disabled=no distance=indoors frequency=auto frequency-mode=\
    regulatory-domain hide-ssid=yes mode=ap-bridge ssid=Tss tx-power=25 \
    tx-power-mode=all-rates-fixed wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
/ip ipsec peer
add name=peer1 passive=yes
add name=dhcp ranges=192.168.1.10-192.168.1.254
add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool2 ranges=10.0.2.2-10.0.2.254
add name=pool-ovpn ranges=10.255.255.2-10.255.255.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add interface-list=LAN local-address=192.168.1.1 name=Ovpn-profile \
    remote-address=dhcp
add interface-list=LAN local-address=10.255.255.1 name=OVPN-profile2 \
    remote-address=pool-ovpn
/queue simple
add disabled=yes dst=192.168.1.250/32 max-limit=10M/700k name=WAN1_total \
    target=WAN1
add disabled=yes limit-at=1M/256k max-limit=10M/512k name=Server_wan1 parent=\
    WAN1_total target=192.168.1.250/32
/queue tree
add disabled=yes max-limit=700k name=uploadWAN2 parent=WAN1
add limit-at=200k max-limit=600k name=Voip_upload_WAN2 packet-mark=fromVoip \
    parent=uploadWAN2
add max-limit=690k name=otherClientWAN2 packet-mark=no-mark parent=uploadWAN2
/system logging action
set 1 disk-file-count=1
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
set discover-interface-list=discover
add comment=defconf interface=WAN1 list=WAN
add interface=wlan1 list=discover
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=WAN2 list=discover
add interface=bridge list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add interface=WAN2 list=WAN
/interface ovpn-server server
set auth=sha1 certificate=Server cipher=aes256 default-profile=OVPN-profile2 \
    enabled=yes port=1200 require-client-certificate=yes
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
    192.168.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=WAN1
add dhcp-options=hostname,clientid disabled=no interface=WAN2
/ip dhcp-server lease
add address=192.168.1.254 client-id=1:6c:3b:6b:ed:b3:5f disabled=yes \
    mac-address=6C:3B:6B:ED:B3:5F server=defconf
add address=192.168.1.251 client-id=1:64:d1:54:46:af:ee mac-address=\
    64:D1:54:46:AF:EE server=defconf
add address=10.0.2.0/24 dns-server=192.168.178.1,8.8.8.8,8.8.4.4 gateway=\
    10.0.2.1
add address=10.255.255.0/24 dns-server=192.168.1.1 gateway=192.168.1.1 \
    netmask=24
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.1 name=router.lan
add action=accept chain=input connection-state=new dst-port=1200 protocol=tcp
add action=accept chain=input comment="Intercomunicazione POOL VPN" \
    dst-address=10.255.255.0/24 src-address=192.168.1.0/24
    dst-address=192.168.1.0/24 src-address=10.255.255.0/24
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-mark=!WAN2 connection-state=established,related disabled=yes
    established,related,untracked disabled=yes
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/ip firewall mangle
add action=accept chain=prerouting comment="Accept da WAN1" dst-address=\
    192.168.178.0/24
add action=accept chain=prerouting comment="Accept da WAN2" dst-address=\
    10.0.2.0/24
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=WAN1 new-connection-mark=WAN1 passthrough=yes
    in-interface=WAN2 new-connection-mark=WAN2 passthrough=yes
add action=mark-connection chain=prerouting comment=\
    "Voip connection mark WAN2" connection-mark=no-mark dst-address-type=\
    !local in-interface=bridge new-connection-mark=Voip_WAN2 passthrough=yes \
    src-address=192.168.1.250
add action=mark-connection chain=prerouting comment="PCC stream WAN1" \
    connection-mark=no-mark dst-address-type=!local in-interface=bridge \
    new-connection-mark=WAN1 passthrough=yes per-connection-classifier=\
    both-addresses:2/0
add action=mark-connection chain=prerouting comment="PCC stream WAN2" \
    new-connection-mark=WAN2 passthrough=yes per-connection-classifier=\
    both-addresses:2/1
add action=mark-routing chain=prerouting comment=\
    "Voip routing mark WAN2_mark chain prerouting" connection-mark=Voip_WAN2 \
    in-interface=bridge new-routing-mark=WAN2-mark passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN1 in-interface=\
    bridge new-routing-mark=WAN1-mark passthrough=yes
add action=mark-routing chain=prerouting connection-mark=WAN2 in-interface=\
add action=mark-routing chain=output comment=\
    "Voip routing mark WAN2_mark chain output" connection-mark=Voip_WAN2 \
add action=mark-routing chain=output connection-mark=WAN1 new-routing-mark=\
add action=mark-routing chain=output connection-mark=WAN2 new-routing-mark=\
add action=mark-packet chain=postrouting connection-mark=Voip_WAN2 \
    new-packet-mark=fromVoip
add action=masquerade chain=srcnat disabled=yes log=yes log-prefix=OVPN \
add check-gateway=ping comment="WAN 2 marked route" distance=1 gateway=\
    192.168.43.1 routing-mark=WAN2-mark
add check-gateway=ping comment="WAN 1 marked route" distance=1 gateway=\
    192.168.178.1 routing-mark=WAN1-mark
add comment="Default route WAN 1" distance=1 gateway=192.168.178.1
add comment="Defult route WAN 2" distance=1 gateway=192.168.43.1
/ip ssh
set forwarding-enabled=remote
/ppp secret
add name=Utente1 profile=OVPN-profile2 service=ovpn
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=hAP
/system logging
add topics=ovpn,debug
/system ntp client
set enabled=yes
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
schadom
Re: Ovpn server on separate pool cannot reach lan
Fri Jul 26, 2019 1:54 pm
We're experiencing the same problem after upgrading to 6.45.1 ...
It's time to finally throw all Mikrotik devices out of the window.
2frogs
Long time Member
Long time Member
Fri Jul 26, 2019 2:11 pm
Try adding this to the top of your mangle rules:
/ip firewall mangle
add action=accept chain=prerouting dst-address=10.255.255.0/24 in-interface=bridge
I believe your rules are too loose and catching any traffic from your LAN to VPN IP ranges.
schadom
Fri Jul 26, 2019 2:22 pm
/ip firewall mangle
That's what we get if the openvpn client tries to ping a host inside mgmt-bridge:
13:19:00 firewall,info prerouting: in:ovpn-instance out:(unknown 0), proto ICMP (type 8, code 0), 10.10.10.20->10.67.68.1, len 84
13:19:01 firewall,info prerouting: in:ovpn-instance out:(unknown 0), proto ICMP (type 8, code 0), 10.10.10.20->10.67.68.1, len 84
13:19:02 firewall,info prerouting: in:ovpn-instance out:(unknown 0), proto ICMP (type 8, code 0), 10.10.10.20->10.67.68.1, len 84
13:19:03 firewall,info prerouting: in:ovpn-instance out:(unknown 0), proto ICMP (type 8, code 0), 10.10.10.20->10.67.68.1, len 84
13:19:04 firewall,info prerouting: in:ovpn-instance out:(unknown 0), proto ICMP (type 8, code 0), 10.10.10.20->10.67.68.1, len 84
Sob
Fri Jul 26, 2019 4:27 pm
Step 1: Packets are coming to router (prerouting, from ovpn-instance) - YES
Step 2: Packets are going through router (forward) - ???
Step 3: Packets are sent to target device (postrouting, to mgmt-bridge / torch on mgmt-bridge) - ???
Step 4: Device responds and sends some packets back (prerouting, from mgmt-bridge) - ???
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
Users browsing this forum: Google [Bot], msatter and 114 guests
