sjoram
Script - ping 'watchdog' - high latency
Sat Jul 27, 2019 3:59 pm
Hi all,
Having looked at various other forum posts, I'm trying to find a script to replace the System Watchdog.
The reason for this is that often when my DSL connection loses sync, the PPP login on RouterOS gives up re-trying to establish PPP after a short time. This then requires either the PPP interface to be disabled/re-enabled, or the router rebooted to re-establish the PPP session.
I have a fault on my DSL at the moment which means I have high latency and some packet loss, which is causing frequent unnecessary reboots via the default watchdog.
Thus what I am looking to do is have a script that when testing ping, I can specify a timeout value that can cope with the high latency, and also specify a number of acceptable lost packets.
Ideally, I would get the script to disable/re-enable the PPP client interface, rather than rebooting the router.
I can't seem to decipher how to do this based on the scripts I've already seen shared. Can anyone help?
Home user, working in IT. Home network is my lab.
ISP: Uno Communications
Hardware:
2x RB750Gr3
Draytek Vigor 120v2 ADSL2+ Annex M
Draytek Vigor 130 FTTC (VDSL)
Users browsing this forum: No registered users and 96 guests
