plisken
Does this mean that these IP addresses were connected to my network and used my network?
Sun Jul 28, 2019 10:04 am
Are these logged in because I doubt that they do not have my login.
I use RouterOS 6.44.5 long term.
jul/26 19:13:41 ovpn,info TCP connection established from 67.21.36.2
jul/26 20:04:38 ovpn,info TCP connection established from 3.14.254.187
jul/26 20:45:24 ovpn,info TCP connection established from 169.197.108.30
jul/26 21:25:04 ovpn,info TCP connection established from 92.118.161.49
jul/27 02:24:24 ovpn,info TCP connection established from 118.193.31.180
jul/27 02:24:25 ovpn,info TCP connection established from 118.193.31.180
jul/27 02:24:31 ovpn,info TCP connection established from 118.193.31.180
jul/27 02:24:35 ovpn,info TCP connection established from 118.193.31.180
jul/27 02:24:41 ovpn,info TCP connection established from 118.193.31.180
jul/27 02:24:42 ovpn,info TCP connection established from 118.193.31.180
jul/27 02:25:48 ovpn,info TCP connection established from 128.14.209.234
jul/27 02:56:04 ovpn,info TCP connection established from 41.65.68.227
jul/27 03:03:44 ovpn,info TCP connection established from 162.209.239.1
jul/27 03:03:45 ovpn,info TCP connection established from 162.209.239.1
jul/27 03:03:46 ovpn,info TCP connection established from 162.209.239.1
jul/27 03:45:48 ovpn,info TCP connection established from 137.226.113.9
jul/27 06:02:38 ovpn,info TCP connection established from 184.105.139.70
sebastia
Re: Does this mean that these IP addresses were connected to my network and used my network?
Sun Jul 28, 2019 12:16 pm
tcp connection is the first step in establishing a vpn session. Then comes authentication of the server and user, and finally ip layer configuration.
this just means that somebody established the first step.
plisken
Sun Jul 28, 2019 1:35 pm
Thank you for your reply Sebastia.
It reassures me that they have not yet entered my network.
Jotne
Sun Jul 28, 2019 5:35 pm
Look at my post here:
viewtopic.php?f=9&t=148397&p=730484#p730484
I did make a script that take those IPSec testers and back lists them for 30 day.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Users browsing this forum: MSN [Bot] and 120 guests
