joelmolina
PROBLEM WITH DNS, RESOLV 0.0.0.0 USING A LOT SPACE IN CACHE
Sat Aug 10, 2019 5:53 pm
First of all, greetings, friends, i have a problem with a server DNS in a router Mikrotik, and I would like you to support me, the problem is, when i see in my DNS Cache register of
resolutions, and i have close a 20 000 resolutions of close 30 000 resolutions, and this use a lot of space, i hope that you help me with this issue, that i dont understand, thx a lot, God Bless you.
(Image Attachments)
msatter
Re: PROBLEM WITH DNS, RESOLV 0.0.0.0 USING A LOT SPACE IN CACHE
Sat Aug 10, 2019 11:39 pm
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.19 / MikroTik APP 1.2.10
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
pe1chl
Sun Aug 11, 2019 12:05 pm
In the setup of IP->DNS set the max TTL to a lower value like 01:00:00
This will clean these entries after 1 hour so they do not accumulate so much.
joelmolina
Mon Aug 12, 2019 6:03 pm
Thanks, this is a good way.
joelmolina
Mon Aug 12, 2019 6:05 pm
thanks so much, this is recommended
joelmolina
Mon Aug 12, 2019 6:27 pm
thanks, with your answer I found this too, that I could contribute something else
https://www.reddit.com/r/mikrotik/comme ... dns_cache/
Users browsing this forum: No registered users and 67 guests
