acssol
Restrict SNMP to use V3 only
Tue Aug 13, 2019 3:42 pm
Hello folks,
i'd like to monitor a MikroTik device via SNMP over the public internet. I therefore would like to allow monitoring via SNMPv3 (with authentication and encryption) only.
As soon as I enable SNMP, I can query the device using all SNMP versions.
Is it possible to restrict querying to SNMPv3 only?
If not - what's the idea behind implementing SNMPv3 as the more secure standard when SNMPv2 is still sending information unencrypted over the network?
Thanks in advance for your feedback!
Elans
Re: Restrict SNMP to use V3 only
Wed Aug 14, 2019 7:52 am
You can use only SNMP v3 for monitoring.
More information about SNMP find below:
https://wiki.mikrotik.com/wiki/Manual:SNMP
acssol
Wed Aug 14, 2019 10:49 am
Hello Elans,
thanks for your feedback. I already knew that wiki article and have read it - but I don't see where it explains how to enable/ disable only certain versions of SNMP.
SNMP is either
enabled (yes | no; Default: no)
Am I missing something?
Elans
Thu Aug 15, 2019 12:57 pm
You have to configure "snmp community" (through GUI it would be IP -> SNMP -> Communities) where you will specify security, authentication protocol etc.
Detailed description about Community Properties:
https://wiki.mikrotik.com/wiki/Manual:S ... Properties
Users browsing this forum: Bing [Bot] and 59 guests
