j5boot
NAT Table with VLAN Firewall
Tue Aug 13, 2019 5:37 pm
Hello everyone
I am configuring a CCR1036 and I have found that with the Firewall activated in the BRIDGE or in VLAN, the packets do not pass through the NAT table. Is this normal or am I doing something wrong?
I am configuring a Hotspot and when I deactivate the BRIDGE Firewall it works correctly, but if I activate it I see no activity.
Can you help me? The VLANs in router is in new-way mode.
Thank you.
/interface bridge settings
set allow-fast-path=no use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/interface bridge vlan
add bridge=bridge tagged=ether1,ether2,ether3,ether4 vlan-ids=70,72
add mtu=1500 name=bridge vlan-filtering=yes
add mtu=1500 name=bridge-70 vlan-filtering=yes
add mtu=1500 name=bridge-72 vlan-filtering=yes
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge-70 interface=vlan-70
add bridge=bridge-72 interface=vlan-72
NAT Table
[admin@VA-CCR1036-INF-1L018-1] /ip firewall nat> print
 0  D chain=dstnat action=jump jump-target=hotspot hotspot=from-client
 1  D chain=hotspot action=jump jump-target=pre-hotspot
 2  D chain=hotspot action=redirect to-ports=64872 protocol=udp dst-port=53
 3  D chain=hotspot action=redirect to-ports=64872 protocol=tcp dst-port=53
 4  D chain=hotspot action=redirect to-ports=64873 protocol=tcp hotspot=local-dst dst-port=80
 5  D chain=hotspot action=redirect to-ports=64875 protocol=tcp hotspot=local-dst dst-port=443
 6  D chain=hotspot action=jump jump-target=hs-unauth protocol=tcp hotspot=!auth
 7  D chain=hotspot action=jump jump-target=hs-auth protocol=tcp hotspot=auth
 8  D chain=hs-unauth action=redirect to-ports=64875 protocol=tcp in-interface=bridge-72 dst-port=443
 9  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=80
10  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=3128
11  D chain=hs-unauth action=redirect to-ports=64874 protocol=tcp dst-port=8080
12  D chain=hs-unauth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
13  D chain=hs-auth action=redirect to-ports=64874 protocol=tcp hotspot=http
14  D chain=hs-auth action=jump jump-target=hs-smtp protocol=tcp dst-port=25
15  X chain=unused-hs-chain action=passthrough
16    chain=srcnat action=masquerade src-address=10.0.72.0/24 log=no log-prefix=""
Users browsing this forum: No registered users and 61 guests
