ShyLion
Disable local echo
Wed Aug 14, 2019 4:12 pm
Hello.
Is there any way to disable local echo on ssh console?
Local echo is then you type something, it prints it back, so your terminal program see that. Makes scripting a pain.
Cendig
Re: Disable local echo
Wed Aug 14, 2019 4:48 pm
Just tested this on a spare hAP Lite ( 6.40.8 ) I have and this does not seem to be default behaviour.
Sounds more like what happens when you use Telnet with command echo turned on...
Also, are you accessing the device with the ssh -t command?
ShyLion
Thu Aug 15, 2019 8:04 am
I'm accessing device using libssh2 library from my programm and i clearly see that devices echoes everything entered back. And that's normal behavior for interactive sessions.
Cendig
Fri Aug 16, 2019 2:48 pm
Ah sorry, didn't realise that you were accessing it this way, not sure how to stop that.
Users browsing this forum: No registered users and 53 guests
