CoolTom
Routing or Bridge for p2p wireless link
Fri Aug 23, 2019 9:36 pm
HI, I am wondering what is "better" (faster/other reason) for wireless p2p link between two lacations. Make it as router to router bridge - one subnet or create subnets between every 2 interfaces on link.
Bridge:
INTERNET ---- ROUTER A (10.0.0.1) -------- (10.0.0.2) ROUTER_WIRELESS_B ********* wireless ********* (10.0.0.3) ROUTER_WIRELESS_C ------ (10.0.0.4) ROUTER D (192.168.1.1) ------ (192.168.1.2) LAN
Routing with subnets
INTERNET ---- ROUTER A (10.0.0.1) -------- (10.0.0.2) ROUTER_WIRELESS_B (10.0.1.1)********* wireless ********* (10.0.1.2) ROUTER_WIRELESS_C (10.0.2.1) ------ (10.0.2.2) ROUTER D (192.168.1.1) ------ (192.168.1.2) LAN
mkx
Re: Routing or Bridge for p2p wireless link
Fri Aug 23, 2019 10:16 pm
Bridge means less package processing on the involved devices ... which means lower delay and possibly higher throughput. However, bridge also means broadcasts (including ARP requests) for the whole subnet will hit all the wireless links (presumably bottlenecks) ... which means somewhat reduced throughput. Same goes for any multicast traffic if IGMP is not in full function (and that's not easy to set-up).
Which effect prevails depends on amount of broadcast/multicast traffic ...
CoolTom
Fri Aug 23, 2019 10:49 pm
Ajaj. So routing? But if TROUTER A and ROUTER D is "hideing" wireless link (subnet 10.0.0.0/24) from rest of the LAN, isnt it OK for bridging?
sindy
Sat Aug 24, 2019 10:32 am
In your particular case, the scheme with bridging where only 4 hosts would be in the 10.0.0.0/x network is fine, as there won't be much broadcast traffic between these hosts.
CoolTom
Tue Aug 27, 2019 4:44 pm
Thanks guys, thats what i wanted to hear :)
Btw would u mind give me some idea for routing in whole network?
viewtopic.php?f=2&t=151566
Users browsing this forum: anav, Bing [Bot], burnduck, djvabe, Google [Bot], Mr47, pmcsill and 116 guests
