aleab
OpenVPN move to another Board
Mon Sep 02, 2019 6:34 pm
i have a RB941-2nD and I have just purchased RBD52G-5HacD2HnD-TC.
my configuration is simple but i have set ovpn server.
can i move certificates from "old" mikrotik to new?
i searched and i found something but is still not working...
i try to do this
on old mikrotik
/certificate export-certificate CA export-passphrase="12345678"
/certificate export-certificate client1 export-passphrase="12345678"
/certificate export-certificate server export-passphrase="12345678"
/certificate export-certificate client export-passphrase="12345678"
then download on my pc
on new mikrotik
/certificate import file-name=CA.crt passphrase=12345678
/certificate import file-name=CA.key passphrase=12345678
/certificate import file-name=server.crt passphrase=12345678
/certificate import file-name=server.key passphrase=12345678
/certificate import file-name=client.crt passphrase=12345678
/certificate import file-name=client.key passphrase=12345678
/certificate import file-name=client1.crt passphrase=12345678
/certificate import file-name=client1.key passphrase=12345678
with command
/certificate print
i noticed that CA certificate is KLAT (like on hold mikrotik, so i suppose is fine)
but server - client - client1 is only K or KT (on old mikrotik is KI)
so I thought I had to sign those certificates.
but when i try to execute
/certificate sign server ca="CA" name="server"
i receive this error
failure: name must be unique!
I think only missing this signature and then it would work...
how can i make the command work?
thank you
Alessandro
sebastia
Re: OpenVPN move to another Board
Mon Sep 02, 2019 8:54 pm
Hi
Normally one only import private key on target/server device. The public part can be distributed to the users of that server.
If Tik is CA, only import private key.
for opvn server: only import private key
for opvn client: only import private client key
aleab
Tue Sep 03, 2019 12:18 am
thank you for reply @sebastia
but if i try to import only key (without crt)
[admin@MikroTik] > /certificate import file-name=server.key passphrase=12345678
certificates-imported: 0
private-keys-imported: 0
files-imported: 0
decryption-failures: 0
keys-with-no-certificate: 0
doesn't import anything...
same result with CA client and client1...
thank you
aleab
Tue Sep 03, 2019 12:56 am
i see when i import a CA.crt creates automatically a CRL
http://127.0.0.1/crl/1.crl
would be that?
thank you
aleab
Re: OpenVPN move to another Board  [SOLVED]
Tue Sep 03, 2019 10:37 am
Sorry, i 'm a idiot...
works fine, it was enough to restart the mikrotik...
so, recap to move openvpn from old mikrotik to new mikrotik
on old mikrotik
on new mikrotik
/certificate import file-name=CA.crt passphrase="12345678"
/certificate import file-name=CA.key passphrase="12345678"
/certificate import file-name=server.crt passphrase="12345678"
/certificate import file-name=server.key passphrase="12345678"
/certificate import file-name=client.crt passphrase="12345678"
/certificate import file-name=client.key passphrase="12345678"
/certificate import file-name=client1.crt passphrase="12345678"
/certificate import file-name=client1.key passphrase="12345678"
reconfig same parameters ovpn server (firewall,dhcp,etc...)
reboot new mikrotik and test...
thank you
Users browsing this forum: Google [Bot] and 76 guests
