DarkOwl
Need help with DMZ config without access to the cameras IP and home automation devices by the WAN
Tue Sep 03, 2019 3:24 pm
Hi, all!
I have a Mikrotik with a PPPoE Client, working with Vlans, Vlan 57 for VoIP and 58 for internet, connected at the interface ethernet 2 in the mikrotik with a DMZ is connected one TP-LINK as main router. I can't access by the WAN to the cameras and home automation devices.
Before putting the Mikrotik, I had internet service with a CPE with Vlans and DMZ like the mikrotik is configured, but with the CPE all works without problems, accessing to the IP cameras and Domotic things, by the WAN.
I attached the mikrotik code, and a explanatory scheme,
Why i can reach the IP cameras in the LAN, but not in the WAN with the mikrotik?
Configuration Code:
[Aitor@0000 - Toni] > /export hide-sensitive
# oct/25/2017 16:03:01 by RouterOS 6.41
# software id = 0B9L-C2WJ
# model = 2011UiAS-2HnD
# serial number = 46740494CBAF
add name=bridge1
add name=bridge2
set [ find default-name=ether4 ] mac-address=64:D1:54:F7:0B:0C name=ether1
set [ find default-name=ether3 ] mac-address=64:D1:54:F7:0B:0D name=ether2
set [ find default-name=ether2 ] mac-address=64:D1:54:F7:0B:0E name=ether3
set [ find default-name=ether1 ] mac-address=64:D1:54:F7:0B:0F name=ether4
/interface wireless
set [ find default-name=wlan1 ] name=wlan3 ssid="0000 - Toni"
/interface vlan
add interface=ether2 name=vlan57LAN vlan-id=57
add interface=ether1 name=vlan57WAN vlan-id=57
add interface=ether1 name=vlan58WAN vlan-id=58
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan58WAN name=pppoe-out1 user=\
    trying1
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 11 default-vlan-id=0
add exclude=dynamic name=discover
add name=dhcp_pool1 ranges=192.168.13.2
add address-pool=dhcp_pool1 disabled=no interface=bridge2 lease-time=1d name=\
    dhcp1
add bridge=bridge1 hw=no interface=vlan57LAN
add bridge=bridge1 hw=no interface=vlan57WAN
add bridge=bridge2 hw=no interface=ether2
add bridge=bridge2 hw=no interface=ether3
add bridge=bridge2 hw=no interface=ether4
add bridge=bridge2 hw=no interface=*5
set discover-interface-list=discover
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add list=discover
add interface=vlan58WAN list=discover
add interface=vlan57WAN list=discover
add interface=vlan57LAN list=discover
add interface=bridge1 list=discover
add interface=bridge2 list=discover
add list=discover
add address=192.168.13.1/24 interface=ether2 network=192.168.13.0
add address=192.168.13.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=192.168.13.1 \
    netmask=24
add action=drop chain=input comment="Drop Invalid connections" \
    connection-state=invalid
add action=accept chain=input comment="Allow Established connections" \
    connection-state=established
add action=accept chain=input comment="Allow ICMP" protocol=icmp
add action=drop chain=input comment="Drop everything else"
add action=drop chain=forward comment="drop invalid connections" \
    connection-state=invalid protocol=tcp
add action=accept chain=forward comment="allow already established connections" \
add action=accept chain=forward comment="allow related connections" \
    connection-state=related
# no interface
add action=masquerade chain=srcnat out-interface=pppoe-out1 src-address=\
    0.0.0.0/0
# no interface
add action=dst-nat chain=dstnat in-interface=pppoe-out1 to-addresses=\
    192.168.13.2
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd interface pages
set 0 interfaces=wlan3
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name="0000 - Toni"
/tool bandwidth-server
set enabled=no
/tool mac-server
DarkOwl
Re: i have a problem, need help
Tue Sep 03, 2019 10:13 pm
up?
DarkOwl
Wed Sep 04, 2019 3:16 pm
noone?
sebastia
Wed Sep 04, 2019 5:02 pm
And what is your question / request?
Also, post config in between < code > tags
DarkOwl
Wed Sep 04, 2019 9:41 pm
Hi, My question is why if i did a DMZ to the another router, i still without access with the Public IP, to the domotic and the cameras.
sebastia
Wed Sep 04, 2019 10:42 pm
post your config, as it's not clear what is what...
/export hide-sensitive (and replace any public ip's)
Jotne
Need help with DMZ config without access to local network?
Thu Sep 05, 2019 8:48 am
Also change your first post and change title from:
to some like this
More people may take time to read it.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
DarkOwl
Thu Sep 05, 2019 3:13 pm
to some like this
Thx, i will make the export, and i changed the title!
DarkOwl
Re: Need help with DMZ config without access to local network
Thu Sep 05, 2019 5:10 pm
Code exposed.
sebastia
Re: Need help with DMZ config without access to the cameras IP and home automation devices by the WAN
Thu Sep 05, 2019 9:08 pm
=> should be on brdige2
mikrotik doesn't have a dmz setting, needs to be done manually
basically, any connection to the router which is "new" (so not part of existing connection from router) should be then dst-nat-ed to .13.2
# this rule will only work if pppoe is actually UP!
add action=dst-nat chain=dstnat in-interface=pppoe-out1 connection-state=new to-addresses=192.168.13.2
# + allow them to be forwarded (although you don't have a drop rule...)
add action=accept chain=forward comment="allow new to dmz" connection-state=new dst-address=192.168.13.2
(ps: typed commands by hand, so a typo is possible)
DarkOwl
Thu Sep 05, 2019 9:35 pm
I think that isnt problem firewall,the firewall is disabled until WAN access works.
So, what should i do, dst nat all the ips for cameras and automaticed devices? like the tp-link port forwarding rules?
sebastia
Thu Sep 05, 2019 10:41 pm
if you want to access each separately, then yes, port forward different ports to specific devices
DarkOwl
Thu Sep 05, 2019 10:46 pm
and for access to all together?
So, why i can access to the Devices with the CPE ubiquiti, but not with my mikrotik, if i did that rule that u can see in nat, redirecting all to the tp-link??¿
sebastia
Thu Sep 05, 2019 11:28 pm
do you have some central management console / server?
and how to you "connect" the these devices from outside? directly or through some cloud feature?
DarkOwl
Thu Sep 05, 2019 11:34 pm
Through cloud feature, using the APPs
sebastia
Fri Sep 06, 2019 2:45 pm
in that case you probably don't need any port forwarding as the camera's are connecting to cloud themselves (from inside to outside)? check it / consult documentation
you'll need to verify how is the app finally connecting to the camera, through cloud or some other manner?
If "some other" manner, additional action may be required
Users browsing this forum: No registered users and 49 guests
