MUM Europe 2020
BatavianX
Low Throughput on 2011  [SOLVED]
Wed Sep 04, 2019 4:30 am
2011UiAS-2HnD
ROS 6.45.5
With minimal config, I only managed to max out at 100mbps, CPU at 100%, when I connect a laptop to my modems, I can get 300mbps++ easily.
# sep/04/2019 08:20:53 by RouterOS 6.45.5
# software id = 08MN-462Z
# model = 2011UiAS-2HnD
# serial number = 5694047FFB97
set [ find default-name=ether1 ] name=ether1.indihome
set [ find default-name=ether2 ] name=ether2.oxygen
set [ find default-name=ether5 ] name=ether5.x-region
set [ find default-name=ether10 ] disabled=yes
/interface pppoe-client
add ac-name=BRAS3-D2-JT add-default-route=yes disabled=no interface=ether1.indihome name=indihome password=XXXXXXXXX service-name=\
    INTERNET user=XXXXXXXXXX@apps.xxxxxx
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] supplicant-identity=x-region.net_fo_TFO-10036
add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=wpa2-psk \
    supplicant-identity="" wpa-pre-shared-key=kambinguling wpa2-pre-shared-key=kambinguling
/interface wireless
set [ find default-name=wlan1 ] arp=reply-only band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto \
    hide-ssid=yes installation=indoor mode=ap-bridge name=wlan01 security-profile=wpa2-psk ssid=SiMeongAnakCantik wireless-protocol=\
    802.11
add name=wifi ranges=192.168.69.0/24
add add-arp=yes address-pool=wifi authoritative=after-2sec-delay disabled=no interface=wlan01 lease-time=30m name=wifi
set discover-interface-list=all
/ip settings
set allow-fast-path=no
add interface=indihome list=WAN
add interface=ether2.oxygen list=WAN
add interface=ether5.x-region list=LAN
add interface=wlan01 list=LAN
add address=192.168.200.2/24 comment=defconf interface=ether1.indihome network=192.168.200.0
add address=192.168.88.88/24 interface=ether5.x-region network=192.168.88.0
add address=192.168.69.2/24 interface=wlan01 network=192.168.69.0
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=ether2.oxygen use-peer-dns=no use-peer-ntp=no
add address=192.168.69.0/24 dns-server=8.8.8.8 gateway=192.168.69.2 netmask=24
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
    in-interface-list=WAN
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=!192.168.0.0/16 new-routing-mark=oxygen passthrough=no src-address=192.168.88.200
add distance=1 gateway=192.168.1.1 routing-mark=oxygen
add distance=1 gateway=indihome
add distance=2 gateway=192.168.1.1
mkx
Re: Low Throughput on 2011
Wed Sep 04, 2019 8:23 am
Any good reason for this setting:
/ip settings
I believe it might kill the RB's performance.
Anyway, there might be two reasons for limit:
  1. ports eth6-eth10 are 100Mbps only
  2. run CPU profile while hammering RB with traffic to see if CPU is bottleneck (and which process is consuming CPU cycles)
BR,
Metod
BatavianX
Wed Sep 04, 2019 9:05 am
I dont know why if
/ip settings set allow-fast-path=yes
I can't open any website at all, ping is good though, I can't even press reply to your post until I disabled it.
I only using port 1 and 5 in the RB.
At one point I disable all the rule and queues leaving only 1 NAT - 1 mangle and 1 route, basically the only rule you need to connect, but still I only manage to max the RB to 120mbps, at this point I can only presume that I got a bad unit, thinking going to x86.
Thanks for your reply.
mkx
Wed Sep 04, 2019 9:15 am
I can only guess (perhaps some other forum guru will come to rescue) ... you have mangle rule which doesn't work if packets, which have to be mangled, are fast-tracked. So disabling fast-path in your case actually causes fast-track to be disabled, making mangle rule working. The proper way of doing it, though, would be to adjust fast-track rule so that it will skip the packets which need to be mangled ...
BR,
Metod
pe1chl
Wed Sep 04, 2019 12:23 pm
A limited performance is likely not caused by "a bad unit".
You should consider that the 2011 is an old device and typical 100 Mbps operation is about what you can expect from it.
Sure there are tricks like fast-path and fast-track to boost performance but they cut into the functionality. You apparently require some of that functionality so you cannot use that.
I have my 2011 connected to a 100 Mbps line and I can see that when I fully load it, the CPU load is considerable.
So I am not surprised that you hit some limit, although I would have expected it to be a little higher.
There are much faster routers in the MikroTik product list today...
sebastia
Wed Sep 04, 2019 1:06 pm
Hey
* with fast-path disabled, fast-track will not work either
* you'll need to exclude 88.200 from fasttrack, or manling for route mark will not work
* You seem to have two wans? indihome + oxygen
is oxygen some vpn for 88.200 only?
* you have in config
add ac-name=BRAS3-D2-JT add-default-route=yes interface=ether1.indihome name=indihome
shouldn't the add-default-route be disabled as the route is already configured manually?
* with fast-path / fast-track enabled 2011 is capable of 300+mbps traffic
edit: some typos
Users browsing this forum: afamative, falconn1 and 120 guests
