gtrappmann
dhcp warning ??
Sun Apr 15, 2007 6:19 am
Hi....
what reasons can be for this log message....
dhcp,warning,info,debug dhcp1 offering lease 1.1.1.52 for 00:13:CE:71:F3:11 without success
any idea ??
thanx
gerd
ahf
Re: dhcp warning ??
Tue Oct 05, 2010 12:26 am
hello all
am also getting same error lately,
dhcp,warning dhcp1 offering lease 10.0.11.148 for 00:C0:CA:39:12:0B without success
dhcp,warning dhcp1 offering lease 10.0.11.14 for A8:7B:39:DC:90:62 to 06:25:82:10:03:D7 without s
uccess
dhcp,warning dhcp1 offering lease 10.0.11.86 for 2C:A8:35:DF:3B:F9 to 06:25:82:10:03:D7 without s
uccess
any advices....
fewi
Re: dhcp warning ??
Tue Oct 05, 2010 12:32 am
The DHCP server offered a lease but the client didn't take it. The two most likely causes are that either the DHCP interval timed out just in time for the server to process the request for the client, but for the client to already have given up, or for another DHCP server being faster and serving the client first.
ahf
Re: dhcp warning ??
Thu Oct 07, 2010 1:35 am
...thats Explains alot..... thanx alot for the reply
Mashimoto
Re: dhcp warning ??
Fri Jul 15, 2011 8:50 am
How do you get it to stop if it's constantly sending that message and always the same MAC?
fewi
Re: dhcp warning ??
Fri Jul 15, 2011 2:19 pm
Don't allow that client on your network. This isn't a problem with the server, the server is doing what it's supposed to.
Specific answers require specific questions. When in doubt, post the output of "/ip address print detail", "/ip route print detail", "/interface print detail", "/ip firewall export", and an accurate network diagram.
Mashimoto
Re: dhcp warning ??
Mon Jul 18, 2011 11:05 pm
SOLVED.
Not sure how to do code so someone else can translate if they like but here's what worked for me:
IP --> DHCP Server --> Leases --> Add new --> General="Pool_Name", MAC Address="MAC address of desired blocked", Server="Name of DHCP Server failing", Block access = yes, Address List = Black-list
Hope that helps someone else
aymoon22
Re: dhcp warning ??
Sat May 11, 2013 11:07 pm
hi all i get same problem it happens in windows 7 and 8 and vista because ipv6 when i disable ipv6 it work will but for people who i did not know where they are i can not fix
mllrycy
Re: dhcp warning ??
Fri Oct 16, 2020 6:18 am
SOLVED.
Hi sir, i would like to ask if this is working im having a same problem with my network
server-LAN offering lease 192.168.63.252 for 20:76:93:54:6B:14 without success
Users browsing this forum: Bing [Bot] and 92 guests
