mhugo
317s storage and temperature acting strange
Sat Sep 21, 2019 12:09 pm
I have a couple of 317s behaving in the same strange way for 2 things I have seen. They are in different locations and run 6.45.6.
Important is that I have at least 4 units with the same symptoms as below so I think they might be related and caused by software or some issue in hw batch.
1) Free space is low but no files on flash.
free-hdd-space: 2500.0KiB
total-hdd-space: 16.0MiB
bad-blocks: 0%
I have tried the fix space npk but no change.
2) High temperature reported but ambient temperature is ok.
CPU load is 0%
temperature: 58C
cpu-temperature: 41C
fan1-speed: 4140RPM
fan2-speed: 3975RPM
We have been on site and its not too hot in the rooms.
/Mikael
mkx
Re: 317s storage and temperature acting strange  [SOLVED]
Sat Sep 21, 2019 2:45 pm
bad-blocks: 0%
That's normal. Built-in flash holds runing ROS, it's just not exposed to you. Only part of flash storage is exposed, but it's highly advisable not to use it fir anything write-intensive ... if flash fails (e.g. due to write-wear), your CRS will become paper-weight.
BR,
Metod
Users browsing this forum: brixsat, mkx, sindy and 141 guests
