In my edge core I use the NAT Same rule to get the entire private network 10.0.0.0/8
The rule does not mention the origin ips, allows all traffic to pass through it
Do I have to expecify the real origin?: 10.0.0.0/8
chain=srcnat action=same to-addresses=50.xxx.xxx.xx/28 same-not-by-dst=no out-interface=sfpp1_WAN0_10GB
With the rule log I am seeing that external ips connect to my public output, is this correct?
Thanks for the help14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.160.160.xx:40661->50.xxx.xxx.68:5921, len 40
14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.160.160.xx:54851->50.xxx.xxx.7:4112, len 40
14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.48:41203, len 40
14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55652->50.xxx.xxx.85:35642, len 40
14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55652->50.xxx.xxx.212:35647, len 40
14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.169.80.xx:20753->50.xxx.xxx.13:81, len 44
14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.181:36969, len 40
14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.24.139.xx:40962->50.xxx.xxx.249:445, len 40
14:02:57 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.20.45.xx:35772->50.xxx.xxx.182:8080, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.137.234.xx:42026->50.xxx.xxx.243:46211, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.248:27687, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55652->50.xxx.xxx.90:40007, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.120:40307, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.137.234.xx:42026->50.xxx.xxx.3:6991, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.137.234.xx:42026->50.xxx.xxx.8:6991, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.180:38365, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto UDP, xx.171.206.xx:36518->50.xxx.xxx.1:33434, len 92
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.96:37102, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.137.234.xx:42026->50.xxx.xxx.148:40508, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.189:26875, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.43:34226, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.137.234.xx:42026->50.xxx.xxx.50:29635, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55652->50.xxx.xxx.55:38665, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55652->50.xxx.xxx.102:38972, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55652->50.xxx.xxx.207:26145, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55652->50.xxx.xxx.210:36339, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55242->50.xxx.xxx.169:22301, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.67:39660, len 40
14:02:58 firewall,info info srcnat: in:(unknown 0) out:sfpp1_WAN0_10GB, src-mac 00:00:00:00:00:00, proto TCP (SYN), xx.57.71.xx:55518->50.xxx.xxx.65:27237, len 40
