metron6
Problem with ip cloud
Tue Oct 01, 2019 6:31 pm
hello all,
the last days, ip cloud service seems to not work..
[admin@5050-oreo] > /ip cloud print
          ddns-enabled: yes
  ddns-update-interval: none
           update-time: yes
              dns-name: xxxxxx.sn.mynetname.net
                status: updating...
has anyone else the same problems ?
Zacharias
Re: Problem with ip cloud
Tue Oct 01, 2019 8:20 pm
What is your routerOS version ?
metron6
Tue Oct 01, 2019 9:22 pm
6.45.6
Zacharias
Tue Oct 01, 2019 9:50 pm
Disable ip cloud and enable again...
metron6
Tue Oct 01, 2019 10:24 pm
i disabled, i rebooted, enabled, still cannot update..
Zacharias
Tue Oct 01, 2019 10:31 pm
You got internet on that router??? :D
metron6
Tue Oct 01, 2019 10:41 pm
of course :)
i can "see" the router via a VPN..
any other suggestion ?
Zacharias
Tue Oct 01, 2019 10:59 pm
Ip cloud does not need any configuration to work...
I do not think there is something wrong with the Mikrotik DNS servers today since i would have noticed it...
Try to update cloud from terminal..
Also, does it say updating forever? Does it change to could not update?
metron6
Tue Oct 01, 2019 11:08 pm
it is disabled...
[le@5050-oreo] /ip cloud> print
          ddns-enabled: no
  ddns-update-interval: 10m
           update-time: no
              dns-name: xxxxxxx.sn.mynetname.net
                status: failed to connect
then from command line...
[le@5050-oreo] /ip cloud> set ddns-enabled=yes
[le@5050-oreo] /ip cloud> force-update
          ddns-enabled: yes
           update-time: no
                status: updating...
updating forever...
Zacharias
Tue Oct 01, 2019 11:17 pm
Why you ve changed the update interval? Let it default... it checks for address change every 60 seconds... so you just make it worst..
Also, is your Date and Time correct at your router?
Can you ping cloud2.mikrotik.com from inside the router?
metron6
Tue Oct 01, 2019 11:23 pm
date and time are ok..
i can ping cloud2.mikrotik.com from both routers..
Zacharias
Tue Oct 01, 2019 11:29 pm
Then it should update...
Otherwise check all your configuration...
metron6
Tue Oct 01, 2019 11:33 pm
router has internet access,
dns are ok (1.1.1.1 & 8.8.8.8),
settings are default...
the strange is that it happens in two routers of the same customer..
and a have other 200 working fine, with same version, etc...
Zacharias
Tue Oct 01, 2019 11:35 pm
Let it for a few hours and then try again...
metron6
Wed Oct 02, 2019 11:44 am
12 hours later, the same.. cannot update
Zacharias
Wed Oct 02, 2019 4:15 pm
Then something prevents it from updating in your router...
nicho15
Wed Feb 03, 2021 4:51 pm
I have the same problem with my 951Ui-2HnD, after updating to 6.48 the ip cloud does not work, I try to ping cloud2.mikrotik.com but without response, the router has internet but it is as if it does not recognize it
gaspo
Tue Sep 07, 2021 2:22 pm
IP cloud doesnt work for me too. impossible ping xxxxxxxx.sn.mynetname.net
rextended
Tue Sep 07, 2021 2:46 pm
And so?
The forum have already 10 topic about that and you resume this old topic?
pukkita
Trainer
Trainer
Tue Sep 07, 2021 2:47 pm
rextended
Tue Sep 07, 2021 6:53 pm
2021-09-07T15:37:37Z
Now is working again.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], qwertykolea and 127 guests
