MUM Europe 2020
Baltos
MT Access Point with more than 2 antennas
Thu Dec 02, 2004 2:14 pm
Dear ALL,
I try to run an ACCESS POINT with 4 sectoral antennas.
But, I can not get it when I install the third antenna.
If I run the third, then one of the first or second antenna will disconnect.
All goods are coming from MikroTik.
What should I consider in implementing such thing ?
eg. all vertical antennas or must be different, distance of each antennas, etc.
thank you :?: :?:
stephenpatrick
Forum Veteran
Forum Veteran
Thu Dec 02, 2004 2:34 pm
Are all the radios on different frequencies?
And I think you should not use adjacent frequencies to avoid the "ACR problem" of radios interfering with each other
Regards
Stephen
CableFree - Wireless Excellence - Microwave, E-band Radios, Free Space Optics, High performance Radios & Routers
http://www.cablefree.net
Baltos
Fri Dec 03, 2004 6:04 am
1. Should the antennas use different polarization ? Means : antenna1-horizontal, antenna2-vertical, antenna3-hor, antenna4-ver ?
2. With difference of how many MHz should the antennas be set ?
Can I use 2 antennas with freq. 1 and 2 antennas with freq. 2 ?
3. Antenna distance to other antenna ??
stephenpatrick
Forum Veteran
Forum Veteran
Fri Dec 03, 2004 12:05 pm
Not sure if different polarisations will help, others may know more.
You can't use the same frequency on any of the 4 antennas
Use non-adjacent channels on adjacent antennas.
Regards
Stephen
mag
Fri Dec 03, 2004 1:28 pm
usually 20 MHz or more, but depends on wireless protocol and local regulations.
no, you shouldn't. they will interfere.
polarisation will help somewhat, but a pair of antennas with same direction is needed. it's therefore good for point-to-point-links only.
regards,
   matthias
mip
Sat Dec 04, 2004 5:00 pm
I do not recommend differebt polarisation, 'cause You will have to routet your clients' antas any time you want to change ap.
https://www.youtube.com/watch?v=j7q0Y_JZMrg - the country you must visit
Users browsing this forum: faxxe, Technetium and 94 guests
