Code: Select all
CRS328
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no name=br-trunk protocol-mode=none pvid=20 vlan-filtering=yes
add bridge=br-trunk interface=ether1 pvid=10
/interface bridge vlan
add bridge=br-trunk tagged=ether1 untagged=ether9,ether10,ether11,ether12 vlan-ids=10
add bridge=br-trunk tagged=ether1 untagged=ether17,ether18,ether19,ether20 vlan-ids=20
/interface vlan
add interface=br-trunk name=vlan10-lan vlan-id=10
add interface=br-trunk name=vlan20-adm vlan-id=20
add address=10.72.17.253/24 interface=vlan10-lan network=10.72.17.0
add address=10.72.18.253/24 interface=vlan20-adm network=10.72.18.0
RB1100AHx4
add name=br-trunk protocol-mode=none pvid=10 vlan-filtering=yes
add bridge=br-trunk interface=ether2 pvid=10
add bridge=br-trunk tagged=ether2 vlan-ids=10,20
/interface vlan
set 1 default-vlan-id=10 # ether2
add independent-learning=no ports=ether2,switch1-cpu switch=switch1 vlan-id=10
add independent-learning=no ports=ether2,switch1-cpu switch=switch1 vlan-id=20
add address=10.72.17.254/24 interface=vlan10-lan network=10.72.17.0
add address=10.72.18.254/24 interface=vlan20-adm network=10.72.18.0
