avrealm
[Issue] Switch management on VLAN
Sun Oct 06, 2019 8:15 pm
Hello everyone,
I have a hex s router with an crs112-8p-4s switch. My hex s and switch are connected via sfp. Ethernet 1 on the switch is going to be a data port on vlan 1 (I haven't really configured that all the way through so you might see that it is incomplete below), and vlan 30 is my management vlan where on the switch is on port 8. When I plug into port 8 on my switch I can see my router and I can an IP address from the dhcp on it on vlan 30, but I cant see my switch's management interface that I set to 10.0.30.2.
Here's my config on the hex s:
# jan/02/1970 06:40:13 by RouterOS 6.43.16
# software id = 7CYF-QWP5
# model = RB760iGS
# serial number = AE370BD2E97B
/interface vlan
add interface=sfp1 name="Data (VLAN 1)" vlan-id=1
add interface=sfp1 name="Mgmt (VLAN 30)" vlan-id=30
add disabled=no interface="Mgmt (VLAN 30)" name=dhcp1
add name=dhcp_pool0 ranges=10.0.30.2-10.0.30.254
add address=10.0.30.1/24 interface="Mgmt (VLAN 30)" network=10.0.30.0
add address=10.0.30.0/24 gateway=10.0.30.1
add action=masquerade chain=srcnat src-address=10.0.30.0/24
/system identity
set name=Router
And here is my switch
# jan/02/1970 07:17:28 by RouterOS 6.42.10
# software id = QARW-E0P8
# model = CRS112-8P-4S
# serial number = 9B2109687BB5
add name=bridge1
/interface vlan
add interface=bridge1 name="Mgmt (VLAN 30)" vlan-id=30
/ip hotspot profile
add bridge=bridge1 interface=ether8
add bridge=bridge1 interface=sfp10
/interface ethernet switch egress-vlan-tag
add tagged-ports=sfp10 vlan-id=30
add tagged-ports=sfp10 vlan-id=1
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=30 ports=ether8
add customer-vid=0 new-customer-vid=1 ports=ether1
add ports=ether8,sfp10 vlan-id=30
add ports=ether1,sfp10 vlan-id=1
add address=10.0.30.2/24 interface="Mgmt (VLAN 30)" network=10.0.30.0
/system identity
set name=Switch
/system routerboard settings
set silent-boot=no
I've tried putting the interface vlan on the sfp port, on the bridge, I've tried this config for the last 2 days and just cant figure it out. I need to be able to see the switch's vlan 30 interface from port 8. Thanks for all your help
CZFan
Re: [Issue] Switch management on VLAN
Tue Oct 08, 2019 1:32 am
You need to add switch1-CPU to the management vlan config, more info here
https://wiki.mikrotik.com/wiki/Manual:C ... s_examples
MTCNA, MTCTCE, MTCRE & MTCINE
Users browsing this forum: No registered users and 86 guests
