ajem22
intervlan routing
Tue Oct 08, 2019 2:55 pm
I made intervlan routing ( to only one host):
add action=masquerade chain=srcnat disabled=yes dst-address=10.1.4.21 \
src-address=10.1.64.0/18
src-address=10.1.128.0/18
add action=masquerade chain=srcnat disabled=yes dst-address=10.1.4.19 \
And I have problem, because max throughput is 60-70 MB/s on first computer, on second is 30-40 MB/s. In one vlan max transfer is 100-110 MB/s on all.
How can I make tranfer faster ?
Board name: RB4011iGS+
Version 6.45.6 (stable)
Anumrak
Re: intervlan routing
Tue Oct 08, 2019 3:12 pm
Hey, you masquerade rules is not an intervlan routing. It's just NAT rules.
Add a scheme of you network please.
ajem22
Tue Oct 08, 2019 3:28 pm
ajem22
Tue Oct 08, 2019 3:30 pm
for example 10.1.64.0/18 and 10.1.128.0/18 have to have access to 10.1.4.21 on tcp, 445 port.
Anumrak
Tue Oct 08, 2019 3:32 pm
What is your ISP link bandwidth?
What is your LACP Link bandwidth between Swicth and Tik? Which links of which media do you use in this bundle? Do you have some phy errors between any of links in a bundle?
ajem22
Tue Oct 08, 2019 3:41 pm
Every red line = 1000MF. LACP = 4Gb/s. ISP 100 Mb/s upload and 20Mb/s send.
I 'm using UTP5e.
mkx
Tue Oct 08, 2019 3:51 pm
inter-VLAN routing is no different than any other routing. Prerequisite is that router has a few vlan interfaces, one for each VLAN which it needs to route. And appropriate IP address set on both interfaces.
By default, ROS will route between any interfaces with IP address attached unless firewall filter rules deny that. And type of interface (VLAN, bonding, ethernet, wireless, PtP) doesn't play any role in this.
Your problem description is too vague to determine where's the data choking. I suggest you to post configuration of your router, at least outputs of /interface export, /ip firewall export and /ip route print ... better yet post complete configuration - output of /export hide-sensitive
BR,
Metod
Anumrak
Tue Oct 08, 2019 4:43 pm
I 'm using UTP5e.
Okay. You mean 100 mb/sec upload and 20 mb/sec download? 100 from you to Internet and 20 from Internet to customers?
ajem22
Script: (other vlans and addresses)
Serwer1 192.168.100.19
Serwer2 192.168.100.21
ajem22
Tue Oct 08, 2019 4:54 pm
sorry , 100 Mb/s download and 20Mb/s upload
Anumrak
Tue Oct 08, 2019 5:07 pm
70 and 40 mb/sec are running simultaneously or by one?
ajem22
Wed Oct 09, 2019 9:24 am
Someone can show me, how It should look like ?
ajem22
Wed Oct 09, 2019 9:31 am
simultaneously
ajem22
Wed Oct 09, 2019 1:10 pm
In intervlan LACP get max 990 Mb/s, in one vlan LACP can reach 2Gb/s. What I can do ?
Users browsing this forum: Baidu [Spider] and 100 guests
