kingportipher
HAVING ISSUES WITH EOIP TUNNEL ON SXT/LHG
Thu Oct 10, 2019 12:16 pm
I am setting up an eoip tunnel between 2 mikrotik devices (RB1100X4 and an SXT lte router over the internet) with host machines connected. I am able to ping the host machines only if i enable torch on the SXT LTE ROUTER.
Without torch running on the SXT router the host machines will not be able to ping each other. I tried with the LHG and i also have to enable torch on it before the host machines can ping each other.
Kindly assist as i am not getting any feedback from mikrotik support.Attached is the copy of design
IPANetEngineer
Trainer
Trainer
Re: HAVING ISSUES WITH EOIP TUNNEL ON SXT/LHG
Thu Oct 10, 2019 4:08 pm
What version of RouterOS is running on each device?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
SiB
Fri Oct 11, 2019 10:07 am
Please check
*) WinBox > IP > Firewall > Connections and WinBox > Tools > Tourch
about this traffic beetween devices. Maybe you confim/discover that traffic is in Tx/Rx correctly send.
*) Add proper firewall chain=input rules to accept this protocol
*) show us the logs
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
Users browsing this forum: No registered users and 81 guests
