MUM Europe 2020
Mrdude
IN v6.45.6 L2TP not use MPPE 128 ?
Thu Oct 10, 2019 2:04 pm
Good day.
In RB2011 in the PPP profile I specify for L2TP I specify the Use Encryption parameter. But the connection is not encrypted, for what reason can this happen?
Zacharias
Re: IN v6.45.6 L2TP not use MPPE 128 ?
Sun Oct 13, 2019 3:52 pm
How can you tell its not encrypted?
Mrdude
Sun Oct 13, 2019 4:07 pm
PPP - Active Conections - Column Encoding is empty when i disable IPsec.But there should be MPPE128 stateless.
r00t
Sun Oct 13, 2019 4:10 pm
Use packet sniffer to sniff start of the PPP connection, then load it into Wireshark. There you will see what protocols and features are negotiated and how (if it's turning of the MPPE128, you will see why, if it's client or server that does that).
But if your PPP profile requires encryption, link should be either encrypted or not connected at all (fails to connect).
Zacharias
Sun Oct 13, 2019 5:22 pm
Enable to your client to require encryption and see if it connects.. if not, then yes it does not use encryption...
Mrdude
Sun Oct 13, 2019 5:40 pm
It is activated, why RB2011 do not use it?
Zacharias
Sun Oct 13, 2019 6:35 pm
If its activated and you can connect then obviously uses it...
Mrdude
Sun Oct 13, 2019 9:16 pm
r00t
Sun Oct 13, 2019 9:22 pm
That looks like a bug, that field should say something.
Also if you switch it to Required, it will not connect unless encrypted.
Zacharias
Sun Oct 13, 2019 9:35 pm
R00t is right.. is your client configured to connect only if encryption is used?
Mrdude
Sun Oct 20, 2019 9:29 am
Please explain what it means "right"? Its settings indicate the use of encryption.
Zacharias
Sun Oct 20, 2019 11:19 am
As i said in my previous post, if the client is configured to only connect if there is encryption, then since you can connect the encyprion is used...
Mrdude
Sun Oct 20, 2019 11:35 am
It is obvious. But, how do I find out why encryption is not turned on if its use is indicated in the profile?
Zacharias
Sun Oct 20, 2019 11:38 am
Are you sure your client device connects only if there is encryption?
Mrdude
Sun Oct 20, 2019 11:41 am
Yes, without encryption, disconnection occurs.
Zacharias
Sun Oct 20, 2019 12:10 pm
Then maybe you should contact mikrotik support...
McSee
Sun Oct 20, 2019 9:28 pm
Set it to required.
Mrdude
Sun Oct 20, 2019 11:10 pm
Set it to required.
Zacharias
Sun Oct 20, 2019 11:58 pm
Mrdude go to the active connections tab, double click the connected client and see if the encryption is mentioned there...
Mrdude
Mon Oct 21, 2019 12:16 am
Zacharias
Mon Oct 21, 2019 12:17 am
So there it is... :lol:
Mrdude
Mon Oct 21, 2019 12:23 am
This customer. which can connect, with mandatory encryption. Kopazany at first can not.
Mrdude
Re: IN v6.45.6 L2TP not use MPPE 128 ?  [SOLVED]
Thu Oct 24, 2019 10:10 pm
Thanks to everyone, the issue is resolved.
Users browsing this forum: abjaterza and 57 guests
