Hello
Why there is a difference between "invalid before"/"expires after" ???
See the picture ..... which one is right ?
Richard
Invalid Before : The date before which the certificate is invalid.
Invalid After : The date after which the certificate will be invalid.
Expires After : Days left until certificate expires.
That is the behavior typical in winbox. Date/time running forward in the future because some offset is doubled or so.same thing in wegfig:
Screenshot is about 2 hours later .... and the time in mikrotik for the certificate has about 4,5 hours past ?!?!?!?!?
Richard
Yes, please provide us with the supout.rif and certificate to support@mikrotik.comin terminal the details are right:
...........................invalid-before=dec/02/2018 11:10:42 invalid-after=dec/02/2019 11:10:42 expires-after=6w2d23h8m21s
so it's a webfig/winbox problem ?????
@krisjanisj
do you still need supout + cert ?
Richard
btw .. is there a way to extend the certificate in routerOS ? ... or is the only way to make a new one with longer term ?
