eXaLiTe
Change a mikrotik USA version to international?
Thu Oct 24, 2019 6:53 am
Good to all, I am in a complication, because I just bought a mikrotik the disc lite5 ac, but it is in the USA version and it has limited fractions, and here in my country I need them to be unlocked in order to use the equipment ... .
What I am looking for is; Who could help me change my team to international?
I think, and I have read that it is done by direct reprogramming of the eeprom, could it be? some clue?
anav
Re: Change a mikrotik USA version to international?
Thu Oct 24, 2019 4:29 pm
Hmmm, i have some capacs here bu they were delivered as International Versions. I simply went into the wifi settings and changed them to conform to Canadian allowable settings.
Can you not just go into wifi settings and set the Country and then apply the necessary changes??
normis
Thu Oct 24, 2019 5:37 pm
Reverse is not possible.
USA version is hardware locked to USA region.
Many110
Sun Apr 25, 2021 1:36 am
Hi
I have the same problem,
i bought Audience LTE from USA. Now i am in middle east and the country setting is locked to United states 3 and canada 2. i have tried with netinstall to put new software, the lock didn't chang. In Kuwait there is no sdistributor.
Do you have any solution for my problem ??
phascogale
Thu Dec 21, 2023 12:59 am
...said ChatGPT more than two years after the event.
chechito
Thu Dec 21, 2023 1:06 am
thank you
Users browsing this forum: loloski and 100 guests
