MUM Europe 2020
ashish
Long time Member
Long time Member
How to manage Network
Sun Apr 22, 2007 2:06 pm
Hi All,
I want to install MT as a Bandwidth Manager in My Network, But Confused with the configuration. PLEASE HELP ME, ITS a Challange for ME.
NOW here is a NETWORK.
LAYER 3 SWITCH With 5 PORT.
Port-1 . 172.16.32.254/23
Port -2. 172.16.48.254/23
Port -5 172.16.160.254/23.
NOW MT with 2 Port.
WAN-> 59.160.X.X - Internet IP
LAN -> 172.16.32.250/23 Connected to LAN.
NOW after Doing routing i am able to ping the whole network which is connected to Layer 3 Switch.
NOW, HOW TO ASSIGN AND MANAGE BANDWIDTH FOR THE WHOLE NETWORK WHICH IS CONNECTED WITH MY LAYER-3 SWITCH.
Is it Possible...???/Please help me out.
ASHISH
firebat
Sun Apr 22, 2007 10:40 pm
How do you want to manage your network? Bandwidth by subent, by specific IP, share equally amongst all users. I assume you are talking about management of your internet gateway connection?
ashish
Long time Member
Long time Member
Mon Apr 23, 2007 5:17 am
Hi thanks,
Want 512Kbps to each IP POOL.
- AP - ASHISH PATEL - 757 309 0236 -
firebat
Mon Apr 23, 2007 6:21 am
Need more info. Do you mean you have DHCP running on each of your five /23 subnets and you want each subnet to get 512K? Have you looked at the BW shaping examples in the documentation?
ashish
Long time Member
Long time Member
Mon Apr 23, 2007 7:03 am
U r right,
There is DHCP running for each subnet. (MT is NOT a DHCP Server). Want to give 512 Kbps to each Subnet.
Thanks in Advance.
balimore
Forum Veteran
Forum Veteran
Mon Apr 23, 2007 7:07 am
U r right,
Thanks in Advance.
yup..
try with mangle and queue tree rules
regards
Hasbullah.com
dvisbal
Mon Apr 23, 2007 4:44 pm
You can configure your Mikrotik at the top of your network, as a bridge, and you can manage your whole traffic with it.
Then you should only create simple queue rules for each IP segment ( ex. target address : 172.16.32.254/23 max upload : 512k max download : 512 k )
Theres another way with queue tree where you can give each segment more bandwith whenever there is bandwith available from other segments.
Dan
ashish
Long time Member
Long time Member
Wed Apr 25, 2007 5:17 am
R u Sure,
If i will PUT MT in between my Network as a Bridge, It will control the whole Network.
Remember that MT is NOT a DHCP Server, Other DHCP server is Leaseing IPs to my NETWORK.
vipul
Wed Apr 25, 2007 1:59 pm
hi ashish
i found in the forum u r form anand -india .i m from dakor and i m going to
establish my wisp .
but i have problem with atheros card
i m using 532a RB with OS 2.9.42 but in wireless interface it shows chipset
AR5413 but my atheros have chipset AR5414 so plz. ashish can u tell me whats wrong ? or is there any setting required?
plz. i hope u help me.
thanx in advance
regards,
vipul
Users browsing this forum: No registered users and 64 guests
