MUM Europe 2020
ste
Route/Ospf Metric/Distance
Mon Apr 23, 2007 2:27 pm
I'm about to do a cleanup of my network and have a look into ospf
and route selection process in my network.
What I am missing is some information in ROS what metrices
my routes actually have.
I see distance, scope and target scope as route attributes.
Distance seems to be the same as on cisco: A parameter
to priorize Routingprotocols. So all ospf learned routes have
the same distance. But where is the actual distance/metrik to
my target ip.
What are these scopes?
Using routing-test on 2.9.42.
Stefan
sergejs
Tue Apr 24, 2007 4:47 pm
MikroTik RouterOS default distances are the following,
protocol default distance
connected 0
static 1
BGP (external) 20
OSPF 110
RIP 120
BGP (iBGP) 200
It is possible to change distance by using 'routing filter' feature.
mag
Re: Route/Ospf Metric/Distance
Tue Apr 24, 2007 5:09 pm
i'd guess one will see different distances only, when exporting routes from one routing protocol into another.
ste
Tue Apr 24, 2007 7:06 pm
connected 0
static 1
BGP (external) 20
OSPF 110
RIP 120
BGP (iBGP) 200
Thanks. But what I'm missing is:
---------------------->8---------------------
gw2>sh ip route 1.1.1.1
Routing entry for 1.1.1.1/32
Known via "ospf 1", distance 110, metric 11, type intra area
Last update from 213.185.129.196 on FastEthernet0/0, 00:01:22 ago
Routing Descriptor Blocks:
* 213.185.129.196, from 213.185.129.196, 00:01:22 ago, via FastEthernet0/0
Route metric is 11, traffic share count is 1
----------------------8<----------------------
the metric field of the route.
My problem is to see why some routes with same distance
are installed via one router and not the other.
I've a complex installation with circles and want to
know exactly what will happen to my network when
one line goes down.
Stefan
Users browsing this forum: Bing [Bot], eworm and 151 guests
