rodolfo
Long time Member
Long time Member
detect new connection without tracking
Wed Nov 06, 2019 5:57 pm
Hi.
To build a protection for syn flood attack, is it possible to consider "new connection" incoming packets with syn flag without using connection-new filter?
The goal is to avoid the use of tracking, to ban source/destination ip causing the flood.
rodolfo
IZ0UQV
mkx
Re: detect new connection without tracking
Wed Nov 06, 2019 6:55 pm
You can create /ip firewall raw filter and as selection criteria use tcp-flags=syn or something.
AFAIK raw firewall rules don't work off connection states ...
BR,
Metod
rodolfo
Long time Member
Long time Member
Wed Nov 06, 2019 7:41 pm
Thanks.
I try to explain better.
Filtering packets in raw, using only the [flag syn] filter,
is the same as filtering packets in forward using the [connection new] filter?
One packet with syn flag identifies always a new connection attempt?
rodolfo
IZ0UQV
mkx
Wed Nov 06, 2019 8:12 pm
That's basics of TCP connection set-up: client sends server packet with SYN flag set and with empty payload. Server replies using packet with SYN and ACK flags set and empty payload. Client then replies with ACK flag set, payload still missing. This concludes "three-way TCP connection setup" and now TCP connection is established. ROS' statefull firewall follows this handshake (seeing first packet the connection is new, remains new during first reply).
Immediately after third packet (ACK without payload) client sends first packet with non-empty payload.
UDP doesn't have connection state (same way as TCP), so ROS makes some shortcuts to get some connection state (I guess it still expects to see some replies to upgrade connection state from new to established) ...
BR,
Metod
msatter
Wed Nov 06, 2019 11:12 pm
And to add, detect sync and add all the other flags and tick the box to have exclamation mark for all except for sync.
UDP you can only detect in Filter because Connection table knows if the connection is New.
You can put it then the block address list and block it in RAW.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta59 / Winbox 3.20 / MikroTik APP 1.3.7
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
rodolfo
Long time Member
Long time Member
Thu Nov 07, 2019 9:03 am
thanks
hence, the following code in the wiki:
ip firewall filter add chain=forward protocol=tcp tcp-flags=syn connection-state=new action=jump jump-target=SYN-Protect
/ip firewall filter add chain=SYN-Protect protocol=tcp tcp-flags=syn limit=400,5 connection-state=new action=accept
/ip firewall filter add chain=SYN-Protect protocol=tcp tcp-flags=syn connection-state=new action=drop
could be written as:
/ip firewall raw add chain=prerouting protocol=tcp tcp-flags=syn action=jump jump-target=SYN-Protect (using correct ! to exclude other flags)
/ip firewall raw add chain=SYN-Protect limit=400,5 action=accept
/ip firewall raw add chain=SYN-Protect action=drop
rodolfo
IZ0UQV
msatter
Thu Nov 07, 2019 1:46 pm
    /ip firewall raw add chain=prerouting protocol=tcp flags=!fin,!rst,!psh,!ack,!urg,!ece,!cwr limit=!400,5:packet action=drop
Running:
Users browsing this forum: No registered users and 96 guests
