nellson
OpenVPN and routing
Wed Nov 06, 2019 9:52 pm
Hi There;
I just bought my first MikroTik RB952UI-5AC2 running 6.45.7, and I almost got everything to work, but I am having a bit of trouble with an openvpn tunnel. The layout is as follows:
Mikrotik (192.168.88.1/24) <-10.30.30.2 openvpn tunnel 10.30.30.1 -> pfsense (172.17.0.1/24)
What works!
The tunnel is up, and the routers can ping each other.
Clients from the pfsense side in (172.17.0.0/24) can ping the openvpn interface on the mikrotik (10.30.30.2).
On the mikrotik router, one can ping clients in 172.17.0.0/24, as long as it it is done from the ovpn-out interface.
What does not work
Clients in 192.168.88.0/24 can ping 10.30.30.2 but not 10.30.30.1 (pfsense ovpn if)
Clients from 192.168.88.0/24 cannot ping clients in 172.17.0.0/24
On the mikrotik router from LAN if (192.168.88.1), one cannot ping 10.30.30.1 or 10.30.30.2
Mikrotik routing table
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 192.168.1.1 1
1 ADC 10.30.30.0/24 10.30.30.2 ovpn-out 0
2 ADS 172.17.0.0/24 10.30.30.1 1
3 ADC 192.168.1.0/24 192.168.1.7 ether1 0
4 ADC 192.168.88.0/24 192.168.88.1 bridge 0
What am I missing here ? :)
sindy
Re: OpenVPN and routing
Thu Nov 07, 2019 11:26 pm
You are missing routes at pfsense towards the 192.168.88.0/24. Be aware that it's not enough to set them in the kernel routing table (indicating the openvpn TUN interface as a gateway), but the openvpn configuration must contain routes too - the kernel routing table sends the packets to the openvpn process, but the openvpn process must route them to the proper client (assuming that the pfsense acts as a server and Mikrotik acts as a client, I haven't found this information in your post).
Mikrotik's implementation of openvpn deals with this automatically (which is unfortunately more than compensated by its drawbacks).
I didn't get the difference between the two cases below:
What does not work
Did you mean, by the second one, that you ping from the Mikrotik itself but with interface=LAN? If so, that's no surprise :)
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: No registered users and 131 guests
