mf761
Traffic Flow incorrect kbit/s
Fri Nov 08, 2019 6:27 am
Hi Everybody,
I try to get a nice overview of my network traffic. I actual use a RBD52G-5HacD2HnD with RouterOS v6.45.7 (stable) and have Traffic Flow IPFIX setup to send to PRTG Monitor.
It seems the transferred Data (total MB) looks correct but the bandwidth usage is total incorrect, i always see values below 1kbit/s.
Example of the Traffic Log is attached (Streams Sensor 2117)
Example of bandwidth usage (Anmerkung.....png)
I tried using Version 5 and 9 as well, but there i even get 0 kbit/s.
Is mabye PRTG Monitor not able to get correct analysis or is there something i should change on the mikrotik?
thanks a lot
michael
jkj
Re: Traffic Flow incorrect kbit/s
Sun Nov 10, 2019 10:38 pm
Did you solve the problem. Have exactly the same one.
Bridge configuration with attached IP address to the Bridge. Expecting all traffic flowing through the Bridge to be recorder by the PRTG
Users browsing this forum: Google [Bot] and 95 guests
