dp466
mAP 2nd PoE out Problem
Fri Nov 08, 2019 7:20 pm
Hi!
im new to mikrotik forum so i dont really know if im at the right place ...
i bought a mAP2 to replace my u-installer (ubnt) that keep failing ...
i setup the mAP's eth2 interface poe option to "Forced on" and im trying to power on a UBNT radio (nbe-5ac-19)
the spec of the mAP say it can deliver 0.5A output ... and the NBE need 0.5 so why isnt powering on ??
Thanks !
[EDIT]
i tried the provided power supplie and it work ... but its not working with USB 5v 2A ...
mkx
Re: mAP 2nd PoE out Problem
Fri Nov 08, 2019 8:45 pm
Ubiquiti needs 24V for powering. And all Mikrotiks able of PoE out deliver same voltage as supplied, they don't adjust voltage (essentially power is pass-through). If you powered mAP with 5V, then PoE out would be 5V ...
And supplied power adapter is 24V, which suits Ubiquiti just fine.
BR,
Metod
Users browsing this forum: No registered users and 129 guests
