MUM Europe 2020
galimuna
Disable NetBIOS via DHCP Server
Tue Apr 24, 2007 3:53 pm
I have a problem on my network... I use the MT DHCP Server on a subnet /22 and my bigest enemy now is Broadcast.
I want to know if there is an option on MT like it is on Windows DHCP to stop NetBIOS on clients through DHCP?
regards,
T.
p.s. Im using MT version 2.8.28
Stoned
Tue Apr 24, 2007 6:24 pm
hello,
this example comes from 2.9.x
add chain=forward protocol=tcp dst-port=135 action=drop comment="" disabled=no
add chain=forward protocol=tcp dst-port=137 action=drop comment="" disabled=no
add chain=forward protocol=tcp dst-port=138 action=drop comment="" disabled=no
add chain=forward protocol=tcp dst-port=139 action=drop comment="" disabled=no
add chain=forward protocol=tcp dst-port=445 action=drop comment="" disabled=no
regards,
Stoned.
tneumann
Tue Apr 24, 2007 11:42 pm
Make sure you have a working WINS/NBNS server in place, then do something like this (adapt IP addresses to your network, of course)
/ ip dhcp-server option
add name="nb-node-type-P" code=46 value="2"
/ ip dhcp-server network
add address=192.168.10.0/24 gateway=192.168.10.1 wins-server=192.168.10.91 \
    domain="mynet.lan" dhcp-option=nb-node-type-P comment=""
( Note: You said you're using 2.8.28 - I don't know if any of this works with a version that old. You seriously need to update! )
--Tom
galimuna
Wed Apr 25, 2007 8:52 am
It would be perfect to update but I have a lot of Hotspot users and DHCP leases ... and I checked on the new versions that It doesnt support my hotspot accounts... and I am to lazy to re-add all of them : :oops:
Is there any possibility to do it on 2.8.x ?
regards,
T.
Users browsing this forum: Bing [Bot], bogdan, SeparateReality, tr00g33k and 129 guests
