I use PPPOE dial-up, and getting an IPV6 address is all normal.
I have set it up correctly, but the tunnel established by EoIPv6 often fails. After finding out the reason, the global IPv6 address is not used to establish the tunnel, but the local address is used. But ICMPv6 uses the correct global address. This tunnel usually fails after the router is restarted and cannot be repaired automatically.
Code: Select all
13:16:40 firewall,info output: in:(unknown 0) out:wlan-client, proto 97, fe80::4e5e:cff:fef2:9407->2409:8a4b:2b5:4b70:ba69:f4ff:fe03:72fb, len 2
13:16:44 firewall,info output: in:(unknown 0) out:wlan-client, proto ICMP (type 128, code 0), 2408:8221:301d:9f78::8080->2409:8a4b:2b5:4b70:ba69:f4ff:fe03:72fb, len 16
13:16:45 firewall,info output: in:(unknown 0) out:wlan-client, proto 97, fe80::4e5e:cff:fef2:9407->2409:8a4b:2b5:4b70:ba69:f4ff:fe03:72fb, len 2
13:16:49 firewall,info output: in:(unknown 0) out:wlan-client, proto ICMP (type 128, code 0), 2408:8221:301d:9f78::8080->2409:8a4b:2b5:4b70:ba69:f4ff:fe03:72fb, len 16
13:16:50 firewall,info output: in:(unknown 0) out:wlan-client, proto 97, fe80::4e5e:cff:fef2:9407->2409:8a4b:2b5:4b70:ba69:f4ff:fe03:72fb, len 2
13:16:54 firewall,info output: in:(unknown 0) out:wlan-client, proto ICMP (type 128, code 0), 2408:8221:301d:9f78::8080->2409:8a4b:2b5:4b70:ba69:f4ff:fe03:72fb, len 16
13:16:55 firewall,info output: in:(unknown 0) out:wlan-client, proto 97, fe80::4e5e:cff:fef2:9407->2409:8a4b:2b5:4b70:ba69:f4ff:fe03:72fb, len 2
13:16:59 firewall,info output: in:(unknown 0) out:wlan-client, proto ICMP (type 128, code 0), 2408:8221:301d:9f78::8080->2409:8a4b:2b5:4b70:ba69:f4ff:fe03:72fb, len 16
