MUM Europe 2020
enioeltz
No ping to IP address
Mon Dec 02, 2019 9:09 pm
Hello
I did a simple configuration with RB750 Hex Lite to establish traffic between two networks, according to the details below:
RB750 Hex Lite version 6.45.7, installed from the scratch with Netinstall.
LAN 1 (client network): 10.150.0.0/255.255.0.0
LAN 2 (VoIP network): 10.153.80.240/255.255.255.248
ETH5: 10.150.60.3/255.255.0.0
One bridge with ETH1/ETH2/ETH3/ETH4
Bridge: 10.153.80.244/255.255.255.248
Router Cisco (VoIP): 10.153.80.241/255.255.255.248 connected in the ETH1
PABX IP: 10.153.80.242/255.255.255.248 connected in the ETH2.
RB 750 config is described below:
add name=Bridge_Vivo
/ip hotspot profile
add bridge=Bridge_Vivo interface=ether1
add bridge=Bridge_Vivo interface=ether2
add bridge=Bridge_Vivo interface=ether3
add bridge=Bridge_Vivo interface=ether4
add address=10.153.80.244/29 comment=LAN_Vivo interface=Bridge_Vivo network=\
10.153.80.240
add address=10.150.60.3/16 comment="LAN Inpol" interface=ether5 network=\
10.150.0.0
/ip firewall service-port
set sip disabled=yes
With this simple config I understand I should be able to ping any IP address on both networks. The problem is I can not ping the PABX IP at IP@ 10.153.80.242. But I can ping 10.153.80.241 of the router Cisco.
This is the situation I am facing. I thank you for any help.
Best regards.
Enio Eltz Filho.
sindy
Re: No ping to IP address
Mon Dec 02, 2019 10:11 pm
How is IP routing configured on the PBX? Can you ping the PBX from the Mikrotik to which it is connected?
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Zacharias
Mon Dec 02, 2019 11:08 pm
Also, what is the gateway IP configured in the PBX ?
Users browsing this forum: MSN [Bot] and 82 guests
