LaKing
Mikrotik Audience and CAPSMAN
Sun Dec 08, 2019 6:01 pm
Hello forum, ..
Is the new Mikrotik Audience AP working with CAPSMAN?
Can I integrate it to an existing capsman network with mainly wAP APs and a cloud core router?
Thank you, ...
Zacharias
Re: Mikrotik Audience and CAPSMAN
Sun Dec 08, 2019 6:13 pm
Audience has the same software (ROS) like all other Mikrotik devices... so yes it can...
normis
Mon Dec 09, 2019 9:06 am
By default, the Audience itself is a CAPsMAN server and will manage other devices or other Audiences you join to it.
But since it's a regular RouterOS device, like all of MikroTik devices, you can clear config and use it as you want.
eworm
Long time Member
Long time Member
Mon Dec 09, 2019 3:06 pm
Looks like these devices have a "join to mesh" button. Is that just reset with cap mode?
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
normis
Mon Dec 09, 2019 4:49 pm
Yes, basically that. MikroTik devices are versatile, these are no different. They are just preconfigured for something you can do yourself.
Here is the button description from the manual:
WeWiNet
Mon Dec 09, 2019 8:22 pm
Normis,
my audience LTE also shows sometimes a "solid green" light ???
No clue what that is as its not mentioned in the user guide.
Any idea?
PS: actually I turned the front lights off as they are a bit too bright. LED with brightness control
would have been nice as this device is on my shelf (it's so awesome...).
WeWiNet
MTCNA
hapac2, map, hap-lite, ltap-mini, RB4011 (good!), Audience (better) :-) !!!
WeWiNet
Mon Dec 09, 2019 8:24 pm
Sorry, got screwed in my comment. (stop laughing at me :-) )
I meant I get a solid green light, but I have only one audience and only set up as
an classic AP!!!
So no mesh mode or capstan etc..
Sorry for confusion (as said I have turned them off already some week ago...)
WeWiNet
MTCNA
Users browsing this forum: Google [Bot], joegoldman, vecernik87, wichets and 115 guests
