Code: Select all
# dec/11/2019 15:53:51 by RouterOS 6.45.7
# software id = BM4W-X3GK
# model = RouterBOARD 962UiGS-5HacT2HnT
# serial number = xxxxxxxxx
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
set [ find default-name=ether3 ] advertise=\
100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
password=xxxxx user=xxxxx
/interface l2tp-client
add allow=chap,mschap2 connect-to=101.99.74.214 disabled=no ipsec-secret=123 \
name=l2tp-out password=321 use-ipsec=yes user=456
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
ap-bridge ssid=xxx wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no frequency=5765 installation=outdoor mode=\
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
xxxxxxx wpa2-pre-shared-key=xxxxxxx
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wlan2
set discover-interface-list=none
/ip settings
set rp-filter=loose
/interface detect-internet
set detect-interface-list=all
add address=192.168.88.x/24 comment=defconf interface=bridge network=\
192.168.88.0
/ip cloud
set update-time=no
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.xx.xx client-id=xx:xx:xx:xx:xx:xx:xx mac-address=\
xx:xx:xx:xx:xx:xx server=defconf
add address=192.168.xx.xx client-id=\
xx:x:xx:xx:xx:x:x:x:x:xx:xx:xx:xx:xx:xx:xx:xx:xx:x mac-address=\
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.88.1 name=router.lan
/ip firewall address-list
add address=192.168.88.2-192.168.88.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
not_in_internet
add action=accept chain=input comment="defconf: accept established,related" \
invalid
add action=accept chain=input comment="Allow ADMIN to Router" \
in-interface-list=LAN src-address-list=allowed_to_router
add action=accept chain=input in-interface-list=LAN port=xx protocol=tcp
add action=accept chain=input in-interface-list=LAN port=xx protocol=udp
add action=drop chain=input
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=accept chain=forward comment="defconf: accept established,related" \
connection-state=invalid
add action=accept chain=forward comment=" Allow Port Forwarding - DSTNAT" \
connection-nat-state=dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="Block iMac1" disabled=yes \
src-mac-address=xx:xx:xx:xx:xx:xx time=\
15h30m-19h,sun,mon,tue,wed,thu,fri,sat
add action=drop chain=forward comment="Block iMac 2" disabled=yes \
add action=drop chain=forward comment="Block iPhone" disabled=yes \
add action=drop chain=forward comment="Block HTC" disabled=yes \
add action=drop chain=forward comment="Block TV 1" disabled=yes \
add action=drop chain=forward comment="Block TV 2" disabled=yes \
add action=accept chain=forward comment="ENABLE LAN to WAN" in-interface=\
bridge out-interface-list=WAN
add action=drop chain=forward comment="Drop All Else"
add action=drop chain=forward dst-port=xx in-interface-list=WAN protocol=tcp
add action=drop chain=forward dst-port=xx in-interface-list=WAN protocol=udp
/ip firewall mangle
add action=add-dst-to-address-list address-list=YouTube address-list-timeout=\
none-dynamic chain=prerouting comment=YouTube content=youtube.com
10m chain=prerouting comment=YouTube-googlevideo.com content=\
googlevideo.com
add action=add-dst-to-address-list address-list=Netflix address-list-timeout=\
none-dynamic chain=prerouting comment=Netflix content=netflix.com
add action=mark-routing chain=prerouting content=reddit.com new-routing-mark=\
vpn passthrough=yes src-address=192.168.88.0/24
add action=dst-nat chain=dstnat comment="Plex Media Server" dst-address=\
0.0.0.0 dst-port=xxxx in-interface-list=WAN protocol=tcp to-addresses=\
192.168.88.xxx to-ports=xxxx
add action=dst-nat chain=dstnat comment="Resilio Sync (UDP)" dst-address=\
0.0.0.0 dst-port=xxxx in-interface-list=WAN protocol=udp to-ports=xxxx
add action=masquerade chain=srcnat out-interface=l2tp-out src-address=\
192.168.88.0/24
add distance=1 gateway=l2tp-out routing-mark=vpn
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh port=xxxx
set www-ssl address=192.168.88.0/24
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=remote strong-crypto=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Asia
/system logging
add topics=wireless,debug
/system ntp client
set enabled=yes server-dns-names=\
0.pool.ntp.org,1.pool.ntp.org,2.pool.ntp.org,3.pool.ntp.org
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
/Codebox]
none-dynamic chain=prerouting comment=Netflix tls-host=netflix.com
chain=preoruting action=add-dst-to-address-list protocol=tcp address-list=reddit
address-list-timeout=none-dynamic log=no log-prefix="" tls-host=reddit.com
chain=srcnat action=masquerade src-address=192.168.88.0/24 dst-address-list=reddit out-interface=l2tp
/code]
