medi01
OVPN mikrotik to mikrotik, no IPs
Sun Dec 29, 2019 8:15 am
Greetings,
I'm trying to test various VPN solutions supported by mikrotik routers.
For each, I create a new pool, profile and secret.
Profile is declaring local IP and referencing the pool.
Exactly the same thing is done for SSTP, PPTP and OVPN (on a non-standard port that is, however, whitelisted in firewall)
All three establish connection, however local/remote address fields are empty for OVPN.
No NAT is used, just routing (and it seems to work fine for SSTP/PPTP).
I'm sorry I do not know how to share configuration script as I'm new to this stuff and have created all that via GUI.
Tried to set IP addresses in "secret",
Any clues? :(
gotsprings
Forum Veteran
Forum Veteran
Re: OVPN mikrotik to mikrotik, no IPs
Sun Dec 29, 2019 4:49 pm
Mikrotik's Version of OVPN has been abandoned for years.
When I first started with RouterOS 10 years ago... OpenVPN was the first thing I had to "Give up on," using Mikrotik. I think i can find the exact post where I asked about OVPN being updated to work with THEN CURRENT standards. "Next RouterOS release..." was the response.
Like I typed... 10 years ago.
Tik to Tik... I use L2TP+IPSec. This works well if one side or both have Dynamic ISP addresses.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
medi01
Sun Jun 28, 2020 1:07 pm
In case other people run into issue: OVPN was actually working, it was just UI not showing IP addresses assigned to the interface.
Users browsing this forum: Chupaka, Pea and 71 guests
