MUM Europe 2020
slv
PPoE server - clients disconected after 5min
Sat Jan 11, 2020 11:25 pm
Hi guys
Since few years I have a mikrotik router acting as a PPoE server for couple of clinets. Everything was ok until last week. Clients started complain that are disconected after few hous, Reboot of router solve this problem for next few hours. Today I remaged (using netinstall) this device from version 6.43.2 to latest 6.44.6 because I've found that this version is vulnerable.
Could someone review my config and advice me what's wrong? How to fix it? This is serious problem for me...
Clients are tplink routers with dd-wrt on it
# jan/02/1970 03:15:31 by RouterOS 6.44.6
# software id = MV38-X1JV
# model = RouterBOARD 750G r3
# serial number = 8AFF089D47AF
set [ find default-name=ether3 ] name=CCTV
set [ find default-name=ether4 ] name=CCTV2
set [ find default-name=ether2 ] name=PPoE
set [ find default-name=ether5 ] name=Trunk
set [ find default-name=ether1 ] name=WAN
/interface vlan
add comment="VLAN 1 - CCTV" interface=Trunk name=_CCTV vlan-id=1
add comment="VLAN 88 - PPoE" interface=Trunk name=_PPoE vlan-id=88
/ip hotspot profile
add name=PPoE-pool ranges=192.168.88.10-192.168.88.99
add name=CCTV-pool ranges=192.168.0.20-192.168.0.200
add address-pool=PPoE-pool interface=_PPoE lease-time=1d name=dhcp1
add address-pool=CCTV-pool disabled=no interface=_CCTV lease-time=1d name=\
dhcp2
/ppp profile
add local-address=192.168.88.1 name=5Mbps rate-limit=1M/5M remote-address=\
PPoE-pool
add local-address=192.168.88.1 name=30Mbps rate-limit=5.1M/35M \
remote-address=PPoE-pool
add local-address=192.168.88.1 name=15Mbps rate-limit=2M/15M remote-address=\
PPoE-pool
add local-address=192.168.88.1 name=10Mbps rate-limit=2M/10M remote-address=\
PPoE-pool
add local-address=192.168.88.1 name=20Mbps rate-limit=5M/20M remote-address=\
PPoE-pool
add local-address=192.168.88.1 name=Unlimited rate-limit=150M/150M \
remote-address=PPoE-pool session-timeout=0s
add local-address=192.168.88.1 name=60Mbps rate-limit=10M/60M remote-address=\
PPoE-pool
/ip settings
set rp-filter=strict
add independent-learning=no ports=CCTV,CCTV2,Trunk,switch1-cpu switch=switch1 \
vlan-id=1
add independent-learning=no ports=PPoE,Trunk,switch1-cpu switch=switch1 \
vlan-id=88
/interface pppoe-server server
add default-profile=5Mbps disabled=no interface=_PPoE service-name=\
PPoE_server
/ip accounting
set enabled=yes
add address=192.168.0.1/24 comment="CCTV Gateway" interface=_CCTV network=\
192.168.0.0
add address=192.168.88.1/24 comment="PPoE Gateway" disabled=yes interface=\
_PPoE network=192.168.88.0
add address=My_IP/30 comment="WAN Gateway" interface=WAN network=\
My_network
/ip dhcp-server lease
add address=192.168.0.3 mac-address=4C:11:BF:C2:D2:52 server=dhcp2
add address=192.168.0.4 mac-address=4C:11:BF:C2:D2:84 server=dhcp2
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router
add address=8.8.8.8 name=google
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
d this subnet before enable it" list=bogons
add address=127.0.0.0/16 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
need this subnet before enable it" list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment=\
"MC, Class D, IANA # Check if you need this subnet before enable it" \
list=bogons
add address=qrba92lhcg1xh7sb.eu list=slawek_new
add action=drop chain=input comment="Drop Invalid connections" \
connection-state=invalid
add action=accept chain=input comment="Allow Established connections" \
add action=accept chain=input comment="Allow ICMP" disabled=yes protocol=icmp
add action=accept chain=input dst-port=8291 protocol=tcp src-address=\
192.168.0.0/24
add action=accept chain=input dst-port=8291 in-interface=WAN protocol=tcp \
src-address=a.b.c.d
src-address-list=slawek_new
add action=drop chain=input dst-port=8291 protocol=tcp
"Allow access to router from known network" src-address=192.168.0.0/24
"Allow access to router from known network" src-address=192.168.88.0/24
add action=drop chain=input comment="Drop anything else"
add action=accept chain=forward connection-state=new dst-address=192.168.0.3 \
dst-port=80 protocol=tcp src-address=a.b.c.d src-address-list=""
add action=accept chain=forward connection-state=new dst-address=\
192.168.0.250 dst-port=80 protocol=tcp src-address=a.b.c.d
192.168.0.251 dst-port=80 protocol=tcp src-address=a.b.c.d
add action=accept chain=forward connection-state=new dst-address=192.168.0.11 \
add action=accept chain=forward connection-state=new dst-address=192.168.0.13 \
"allow already established connections" connection-state=\
established,related
add action=accept chain=forward connection-nat-state=dstnat connection-state=\
established,related in-interface=WAN
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
bogons
add action=drop chain=forward disabled=yes in-interface=WAN
add action=accept chain=forward out-interface=WAN
add action=drop chain=forward comment="drop invalid connections" \
connection-state=invalid protocol=tcp
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=WAN to-addresses=0.0.0.0
add action=dst-nat chain=dstnat dst-port=8031 in-interface=WAN protocol=tcp \
to-addresses=192.168.0.3 to-ports=80
add action=dst-nat chain=dstnat dst-port=8032 in-interface=WAN protocol=tcp \
to-addresses=192.168.0.11 to-ports=80
add action=dst-nat chain=dstnat dst-port=8033 in-interface=WAN protocol=tcp \
to-addresses=192.168.0.250 to-ports=80
add action=dst-nat chain=dstnat dst-port=8034 in-interface=WAN protocol=tcp \
to-addresses=192.168.0.251 to-ports=80
add action=dst-nat chain=dstnat dst-port=8035 in-interface=WAN protocol=tcp \
to-addresses=192.168.0.13 to-ports=80
add distance=1 gateway=GW_IP
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ppp secret
[snipped]
add name=nm50 password=ro2cho profile=Unlimited service=pppoe
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=Router
/system note
set note=">>>> Authorized administrator only. Access to this device is monitor\
ed <<<<"
/system ntp client
set enabled=yes primary-ntp=212.244.36.227 secondary-ntp=212.244.36.228
I will upload pictures with logs soon.
Port 1 is connected to cable modem, port 5 (trunk) is connected to switch. Other Mikotik ports are not used as they are not properly working as untagged ports.
LAN 192.168.0.0 is working properly.
slv
Re: PPoE server - clients disconected after 5min
Sat Jan 11, 2020 11:42 pm
After all clinets are in broken state, Router logs are filled like above.
I will try to catch moment when Client went to broken state.
slv
Sun Jan 12, 2020 2:57 pm
Hi
In broken state logs are full of:
and
After full reboot of switch witch connecting ppoe Clients and Mikrotik routers all session started but logs are full of:
Have you any idea what's wrong here?
Regards
Slawek
slv
Sat Jan 25, 2020 4:34 pm
Hi guys
I count on you!
Could you give me some advices about my configuration? How to solve my problems? Have you any idea?
Regards
Slawek
flynno
Sat Jan 25, 2020 5:09 pm
Have you tried removing the IP address set on the pppoe server? you dont need to have an address set for the pppoe interface just a ip pool for clients
slv
Sat Jan 25, 2020 8:29 pm
Hi Flynno
This is example of my profile:
/ppp profile
set *0 use-encryption=no
PPoE-pool
and here is server prfile
[admin@Router] /interface pppoe-server server> print
0 service-name="PPoE_server" interface=_PPoE max-mtu=1480 max-mru=1480
mrru=disabled authentication=pap,chap,mschap1,mschap2 keepalive-timeout=10
one-session-per-host=no max-sessions=unlimited pado-delay=0
default-profile=30Mbps
as you can see it using _PPoE interface.
From where I should remove IP address - from server only? Do I'm right? so I should remove interface _PPoE from server profile?
slv
Sat Jan 25, 2020 8:32 pm
Finally I caught moment when client was disconnected:
Some screenshots from logs:
IPANetEngineer
Trainer
Trainer
Sat Jan 25, 2020 8:35 pm
A few questions
1. How many PPPoE sessions do you have?
2. What is the total throughput?
3. Did you recently add more clients?
4. What do the CPU/Memory resources look like?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
flynno
Sat Jan 25, 2020 9:17 pm
Ok, you have your pppoe server set on a vlan and its set on interface Trunk which is ether5 from what I can see in your config.
/interface vlan
Can you remove this
add address=192.168.88.1/24 comment="PPoE Gateway" disabled=yes interface=_PPoE network=192.168.88.0
Delete the DHCP server for the pppoe
Keep the IP pool for the pppoe
Can you not create a bridge and put the pppoe server on the bridge or else put the pppoe server on the vlan88 and take it off ether2 port
slv
Sun Jan 26, 2020 12:33 am
A few questions
Ad1. less than 20, usually around 16
Ad2. generally 30Mb per session, ISP connection is 300Mb/30Mb
Ad3. No
Ad4. current state is: CPU 1%, Memory 194MB
This is RB750Gr3 (two cores 800MHz, 265MB ram) so in my opinion plenty od resources for my small deployment
slv
Sun Jan 26, 2020 12:41 am
/interface vlan
I've checked from Winbox and this is greyed out - so its already disabled
I don't understand this, could you elaborate it a bit more?
I prefer to not use bridges, I've tryed to setup trunk port and two vlans. It's working (or almost working)....
Regards
Slawek
slv
Sun Jan 26, 2020 12:43 am
One more question. How to export logs from memory to disk? The whole buffer.
flynno
Sun Jan 26, 2020 3:59 pm
/interface vlan
ether5 is named interface=Trunk and on ether2 is ppoe what port is ether2 been used for? it's named ppoe
PPoE_server
Have you tried putting the PPPOE Server on TRUNK instead of _PPoE
slv
Sun Jan 26, 2020 6:17 pm
Hello Flynno
At very beginning I had idea to use Mirotik ports as access ports. Unfirtunetelly I have never manage it to be working. I have no idea why we can't configure such basic network function as a VLANs are. Hopefully I manage proper TRUNK port on ethernet5 interface.
I have only remote access to this router so I have limited possibility to play with it ;).
Since yesterday when I had outage, (all Clients was disconected) today everything seems to be working.
I will change pppoe-server interface to Trunk when I will have another outage.
My current settings looks like (this time I've used print with detail option to show all options) :
[admin@Router] /interface pppoe-server server> print detail
0 service-name="PPoE_server" interface=_PPoE max-mtu=1480 max-mru=1480 mrru=disabled authentication=pap,chap,mschap1,mschap2 keepalive-timeout=10 one-session-per-host=no max-sessions=unlimited pado-delay=0 default-profile=30Mbps
[admin@Router] /interface> vlan print detail
0 R ;;; VLAN 1 - CCTV
name="_CCTV" mtu=1500 l2mtu=1592 mac-address=CC:2D:E0:B4:9A:04 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=1 interface=Trunk use-service-tag=no
1 R ;;; VLAN 88 - PPoE
name="_PPoE" mtu=1500 l2mtu=1592 mac-address=CC:2D:E0:B4:9A:04 arp=proxy-arp arp-timeout=auto loop-protect=default loop-protect-status=off loop-protect-send-interval=5s loop-protect-disable-time=5m vlan-id=88 interface=Trunk use-service-tag=no
I'm curious how is possible that this two vlan interfaces has the same MAC address.
Users browsing this forum: Andrejm, bgpro, Bing [Bot], marisspringis and 135 guests
