MUM Europe 2020
lauchuenfeng
http access from winbox
Mon Jan 13, 2020 5:35 pm
Hi all,
i found actually there is a "built in browser" in winbox manual option, we can google it/ using it as browser. However the address bar is not displayed, we had some router that can only using http access to configure it, so is there anyway that we can http access from our core router to our client router using winbox? then we are able to remote access it.
Or it can be a new function for the next update? :)
Zacharias
Re: http access from winbox
Mon Jan 13, 2020 8:29 pm
Why would that be useful ? :shock:
lauchuenfeng
Tue Jan 14, 2020 4:32 pm
For example we had Tplink router that gain private ip as their pppoe ip, so i can remote access to my core router (using public ip), from there i open the browser http access to the tplink router(core router are able to ping tplink private ip) for troubleshooting purpose or change configuration without onsite customer premise.
lauchuenfeng
Tue Jan 14, 2020 4:42 pm
i understand this can be done if we vpn back to the core router, but will prefer if there is alternative way to do it
Zacharias
Tue Jan 14, 2020 4:59 pm
And this is the only correct way...
Users browsing this forum: Bing [Bot], gibi13, Znevna and 154 guests
